My 2004 says SRS should be "Serviced", unspecified how.
Today I've been to the dealership and ordered a new exhaust manifold screw. The gasket is leaking towards the edge and while investigating I noticed the manifold is missing a screw. Hopefully that'll do it.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I didn't know the airbags were meant to be replaced, I though they were meant to be inspected at 10y old? Good to know Volvo says now they are safe even past 10y, feel safeabscate wrote: 06 Dec 2017, 14:54 Quick note on that SRS plate - the sticker used to say replace the SRS after 10 years, but there was a TSB that said this was no longer necessary.
- Been thanked: 4068 times
It might have been a P80’sticker that said that and P2 stickers were differentoragex wrote: 06 Dec 2017, 15:38I didn't know the airbags were meant to be replaced, I though they were meant to be inspected at 10y old? Good to know Volvo says now they are safe even past 10y, feel safeabscate wrote: 06 Dec 2017, 14:54 Quick note on that SRS plate - the sticker used to say replace the SRS after 10 years, but there was a TSB that said this was no longer necessary.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
That floor mat I got out of that pick and pull car... even though it looked pretty good, 2 days in a row I got in the car and could smell something a little 'earthy'. So I brought the mat back in the house and cleaned it in a large tub full of hot water, upside down while working the pile instead of just going over it endlessly with the upholstery cleaner wand. I can't get over how much sand and grit was trapped deep down in the pile. The first round of cleaning pulled a ton of dirt out already. What looked like minor damage wear in a couple spots fluffed back up as the stuff embedded down in the pile came out.
Edit, after drying overnight and a dachshund style ultra scrutiny sniff audit, it went back in the car and I think I'm good now.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Bought it!
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
You should mention the '05 base in another thread is what you're talking about. I mean...
....we all get along here but we don't share a common nervous system.
Upon further review.....the car in the earlier thread title has been changed to an '06....a "Long Island car" , no less.
For those who don't know, the rumor is that salt is not used on Long Island roads because it would pollute the aquifers.
I don't know if that is true or not.
Good luck with it.
Good luck with it.
They do salt on Long Island - and believe they use brine rather than rock salt in 'most' municipalities - where "most" is an unqualified adjective with no factual support, intended to strengthen the statement legitimacy.
JRL
- Year and Model: Several
- Been thanked: 16 times
That would have nothing to do with your SRS servicing. You actually brought it to a VOLVO dealer and they told you nothing???!!!Rattnalle wrote: 06 Dec 2017, 14:59 My 2004 says SRS should be "Serviced", unspecified how.
Needs to be hooked up on VIDA to see what actually is bad. However, if you have an SRS light that means your airbags are not working...none of them!
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I should probably have quoted but the first part was I relation to the ten year replacement discussion, not my car.JRL wrote: 11 Dec 2017, 14:52That would have nothing to do with your SRS servicing. You actually brought it to a Volvo dealer and they told you nothing???!!!Rattnalle wrote: 06 Dec 2017, 14:59 My 2004 says SRS should be "Serviced", unspecified how.
We figured it out, Ratnalle. Well, most of us did.
