Correct, except we don't assume that old guide pin is out. The old guide pin is out when you do follow and chase. When your finished with that, you can do your stalking without hindrance.
1995 855, wheel guide pin borken off
- RickHaleParker
- Been thanked: 980 times
So, we assumed that old guide pin was already out ? Then we use tap to clean up the thread ?
Active
Past
Past
- RickHaleParker
One more tip, soak it good with liquid wrench and use a left hand drill bit. You might get lucky and the broken part will back out as the left hand drill bit bites. That how I got a broken head bolt out of a Volvo 2.9.
Active
Past
Past
- Has thanked: 312 times
- Been thanked: 818 times
Right - see post #3.
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
While the guide pin is not strictly necessary, it makes reinstalling your wheel a real hassle. I know because I have a broken pin.
Someday, I will get the sheared off pin out of the hub. In the meantime, a guy at my local tire store gave me a little aluminum tool that is basically a rod with the appropriate threads on one end. You screw this into any lug hole after aligning things, install the wheel and remaining lugs, then remove the tool and replace the last lug. Easy peasy.
If you can't get this special tool, just get a long bolt with the correct threads and cut the head off. It will function in the same manner. You could bring one lug from your car into your local hardware store and match up the size and threads to something at the store.
All U.S. market models.
All running and on the road.
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
[quote=Eddystone post_id=457138 time=1513085869 user_id=67572]
... a guy at my local tire store gave me a little aluminum tool that is basically a rod with the appropriate threads on one end. You screw this into any lug hole after aligning things, install the wheel and remaining lugs, then remove the tool and replace the last lug...
IPD sells the one in the link below for the P2 and P3 cars (and used to sell one for the 850s as well), a little steep and a bolt may work as well.
https://www.ipdusa.com/products/11713/1 ... tall-guide
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
lcc014
- Year and Model: 855, 1995
- Has thanked: 2 times
- Been thanked: 11 times
gmh wrote: 12 Dec 2017, 17:05I have a similar guide pin for my BMW. BMW has no guide pin and this tool make it easy to put back the alloy wheels.Eddystone wrote: 12 Dec 2017, 06:37 ... a guy at my local tire store gave me a little aluminum tool that is basically a rod with the appropriate threads on one end. You screw this into any lug hole after aligning things, install the wheel and remaining lugs, then remove the tool and replace the last lug...
- Eddystone
Yup. Looks very similar to that, but mine is aluminum alloy. The key bit of info from the IPD listing is the thread:gmh wrote: 12 Dec 2017, 17:05 IPD sells the one in the link below for the P2 and P3 cars (and used to sell one for the 850s as well), a little steep and a bolt may work as well.
M14 X 1.5 THREAD PITCH
Now, we know what size bolt to buy and grind the head off of.
- Has thanked: 1611 times
- Been thanked: 4075 times
This will cost a bit more if you buy it in stainless but then cutting the head off will be easy. Chase the thread with a nut when done, then tape the end with car colour matching tape
Can't wait to do this, great idea!
