DIY: 1998 S70 GLT Trans Cooler Line Rebuild for $10!
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Those connections look great! Where did you get the nice set of Oetiker crimp pliers shown in the first photo?
- phils94850
- Year and Model: 2009 s60 turbo
whats everyone's thoughts on a front mount trans cooler ? I got one off a caddy at the JY and installed and it seems to be working great. Im planning on installing a in-line trans filter as well....
1996 Platinum Edition
- Been thanked: 504 times
Jason,jreed wrote:Those connections look great! Where did you get the nice set of Oetiker crimp pliers shown in the first photo?
I got these Oetiker clamps on ebay for cheap. Thee is an ebay seller named john102561.
He sells Oetiker clamps, usually a set of 10 for $2.50 ---> $3.00.
This is what I did:
- Go to ebay and search "Oetiker clamps".
- Find john102561 listings.
- Buy different sizes: I bought 8mm all the way to 16 mm. It cost me some $25 for this assortment.
- Then I store them in well-labeled clear plastic container (hardware store sells this container for $4).
You will appreciate this collection when you need to fix odds and ends and need an Oetiker clamp in an instant!
BTW, It is much more expensive to buy a ready-made Oetiker assortment box ($60+) and they usually do not have the assortment you want.
- jreed
Thanks! Looks like a great deal on Oetiker clamps.
Cn90, awesome write up! I had the oil cooler line start leaking on my 98 xc70 last week, and I used this method. For those that want to fix the oil line with this method, you will need larger line than the 3/8". No auto parts stores local had a size large enough in trans line. I wound up at a local hydraulics company and got some 1/2" line. The old line is a 12mm line, but I wasn't able to find it quickly, the 1/2" fits bit not as snug as I would like to see it, so I used a little soft setting sealer on it just to make sure it didn't leak. So far so good near 500mi on it. I'll update later on for you guys.
99 V70xc Darkwing (gone
08 xc90 Tabitha
06 V50 T5 Awd 6spd. Skeeter
66 barracuda "very long term project"
08 xc90 Tabitha
UPDATE 4y/40K miles later.
- Zero leaks, Oetiker clamp area looks good.
- @Oitsujosh, my 3/8-inch hose is fine. I don't know about XC model, but for FWD model, the 3/8" line is fine.
- 11 Replies
- 6697 Views
Last post by foggydogg
- 2120 Views
- 2071 Views
Last post by shiloh51933
- 32 Replies
- 17930 Views
Last post by sleddriver
- 1249 Views
Last post by BackRoadSeeker
