Hey everyone! I have had it to here with this Volvo!
I’m losing coolant like crazy! As soon as the engine is hot I get bubbling coming up through the cap. To the point where I just started using water. The car has not overheated. I just ordered a new reservoir and cap from partsgeek.com but before I keep throwing money at the cooling system, does anyone had insight on what this could be? The only thing I’ve replaced is the alternator about 3 weeks ago... so that’s not connected...
Hayley
Volvo 850 reservoir tank boiling
MrsJones1988
- Year and Model: 1996 850 GLT
CEBirnley
- Year and Model: 1998 V70 Base FWD
- Has thanked: 13 times
Just spitballing here...it could be an issue w a cracked cap, reservoir or hoses. It’s my understanding the system needs to be pressurized and of a leak is present, then it cannot be properly pressurized.
I’m looking forward to seeing what the more learned folks have to say.
MrsJones1988
So should I hold off on replacing the radiator and t-stat?
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
If it isn't overheating and there are no leaks from radiator it isn't due for replacement. T-stat normally only if the water temperature drops when driving long straights.
Replace the reservoir cap for starters before throwing more money at parts you likely don't need to swap out yet. Keep in mind that water alone actually lowers the temperature at which it'll start boiling, where the 50/50 recommended mix of HOAT coolant/distilled water will raise the boiling temp. (Not to mention if it's tap water you've put in, you may face problems with calcium and other deposits in the cooling system and engine.)
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
- RickHaleParker
- Been thanked: 978 times
Hold off radiator and t-stat.
Any white smoke coming from the tail pipe?
Does the bubbling from the reservoir smell like exhaust fumes?
Pull the plugs: Water droplets, brown spotting, and rust around the threads are all signs of head gasket failure.
A compression test might be telling.
Active
Past
Past
- Has thanked: 2199 times
Some places like Autozone also loan tools. See if they have a cylinder head gas leak tester. Basically you attach the tool to the header bottle and it has a fluid that changes color if there are exhaust gases getting into the coolant. If gases are getting into the coolant system you have a head gasket leak. You may not get white smoke from the tailpipe if the gas leak is only into the coolant.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Very likely poor seal on reservoir cap. Could be a very simple fix. I've been lucky like that once before.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
MrsJones1988
Thanks! I will start with the simple things and work my way up. Hopefully it’s a simple fix. There’s always a puddle directly under my reservoir so maybe I’m just overthinking. I don’t have white smoke out tailpipe but I am getting white smoke out of the oil dipstick but from the looks of it, that’s the PCV system correct?
Yes that is typically the PCV system needing cleaned.
Testing the coolant for gases is a simple thing to do before you go throwing money at it. If there is a junkyard around where you live you might be able to get a black cap from a 240 which allows a higher pressure before letting fluid out.
MrsJones1988
Neil, how do I test the coolant for gases? And can you explain the purpose of doing this? Is it to figure out if it’s the head gasket or what?
- 1052 Views
Last post by macten100
- 3658 Views
Last post by christhegamer
- 1250 Views
Last post by oragex
- 9 Replies
- 1606 Views
Last post by Goupil
- 2694 Views
Last post by JimBee
