Install trip computer 850 T5 -94
So i got a trip computer from the yunk yard, but it has the green cable to it. And mine has a gray cables so it won´t work. I was wondering does any 850 have a trip computer with gray cable? I get the stuff from the yunk yard free so thought i should install one. But not sure if any 850 has the trip computer with gray cable :/ I have a 1994 T5
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
https://volvoforums.com/forum/volvo-850 ... ght-71573/
Volvo had 2 different type of speedometers in 1994. This link can explain much better than I.
Ok i see, well mine looks like the vdo one, but i have the gray cable on it. And i have the short display with clock only. Guess i will have to find another 850 and see if that computer trip have the gray cableshaker_chi wrote: 26 Dec 2017, 20:55 https://volvoforums.com/forum/volvo-850 ... ght-71573/
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
Sounds like your problem is the same as it was in this old thread here: viewtopic.php?f=1&t=26962
Wonder if it's this one you need?
https://www.ebay.co.uk/itm/Volvo-850-Tu ... 2629658667
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
That would be the one i guess, see if i can find one at the yunk yard thenTeddy1975 wrote: 27 Dec 2017, 08:34 Sounds like your problem is the same as it was in this old thread here: viewtopic.php?f=1&t=26962
Teddy1975
I wish you luck
Please, see the PM I've sent you.
/Teddy
/Teddy
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Yes those clusters evolved in production. You need to get a matching one or replace the entire cluster.
- Has thanked: 311 times
- Been thanked: 817 times
As mentioned by rspi, getting a cluster to match the other trip computer might be an easier way to go. Every car at the junkyard has a cluster, only some have trip computers.
