The coils each ground through the M6 bolts as well as the wiring harness
These coil packs have the primary's power stage built into the coil pack.
The M6 bolt is the ground for the power stage. The secondary winding is grounded through the wire harness.
M6 bolt, Power Stage ground.
Solid Black, Secondary Ground.
Red, Common Primary Coil supply voltage.
Yellow, Common Power stage collector voltage from ECM.
X/Black Power stage control signal from ECM. X is a different color for each of the five cylinders.
Yet Another ETM Thread
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
At least I'm tech-savvy enough to drop this pic in. For reference, this is on the driver's side going into the intake manifold. Looks like a sensor of some kind, and probably broke when I had this line laid back for removing the manifold. It was cracked when I found it, it easily peeled back as you now see in the photo. Might this have anything to do with my problems? I'm sure it can't help. I tried taping it into place but that sure didn't help matters.
Thanks for all the comments I haven't responded to ... I'll check on these things. I've foolishly chosen to start this work in an open carport ... should've moved the vehicle to my heated shop before starting this work. Suffice it to say work is slow, with many breaks to warm numbed fingers & frozen feet.
Thanks again to all who are assisting.
- Has thanked: 1611 times
- Been thanked: 4072 times
Lol
That's a massive vacuum leak direct into the intake manifold right where it will do its worst.
It's the brake " ejector pump" which is a clever way of making sure your power brakes have boost under all engine running conditions
So, once you get it plugged up and your engine running we'll, you will find you have no brakes.
OK, while you're LOL ... I'm not!!! Obviously it's a massive leak now, but it was just a hard-to-see crack before I went ahead & peeled it back. So now that's identified I'll look for the part(s) to square this away. Wouldn't hurt to check on all the other issues everyone has brought up as well.
Booster Vacuum Ejector? Looks like part # 30665561 ... found it on FCP. Excellent - I like sub-$100 parts. Obviously needs to be replaced, and I would very much like this to be that magic bullet to get this vehicle mobile again.
And ... going back to the original failure, I assume if this failed catastrophically then that could explain why it was running fine one minute and sputtering the next.
Finding a massive vacuum leak on a Volvo translates into Swedish as ...a good start.
Keep looking at all the vacuum lines , take them off. Blow into them and listen, feel for defects
- RickHaleParker
"should've moved the vehicle to my heated shop before starting this work. Suffice it to say work is slow, with many breaks to warm numbed fingers & frozen feet."
Don't kick yourself, your not the only one that has made errors in judgement due to weather.
Det är en bra början
Active
Past
Past
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Jatte bra, RHP.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- RickHaleParker
Jattebra, RHP.
Don't pat me on the back too much. I only learned enough Swedish to swear when a repair not going well. Swearing at a Volvo in English does no good.
Active
Past
Past
If you Volvo your own, anger goes away. Check local laws before you Volvo.
- 21 Replies
- 5646 Views
- 5362 Views
Last post by V50RobC
- 24 Replies
- 4085 Views
- 9 Replies
- 4532 Views
Last post by xHeart
- 3496 Views
Last post by polskamafia mjl
