Anyone running 215 *75* 16's on their XC70?
Brandon_K
Year and Model: 2003 XC70
Post by Brandon_K »
I tried searching for tire fitment, but it says the terms are too generic so it won't let me.
Anyhow, I have the opportunity to pickup some Hakkapeliitta's from a special order that was canceled for dirt cheap. They are 215/75's. Tread width is the same, which is fine since I prefer a narrow tire in the snow, but it's a little shy of 2" larger in diameter. I don't see any obvious issues with fitment, but figured I would run it past you guys before I buy them as they're a cash deal.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
It may rub near full lock and the speedometer will show a few kmh less than the real speed.
Brandon_K
Post by Brandon_K »
Is that a "you can run them for sure" or is that a stab in the dark?
I'm aware of the speedo being off and I'm run with rub at full lock, I'm more concerned about suspension articulation rub as that, I can't control.
oragex
Post by oragex »
It is not an answer to the question, perhaps a clear answer is hard to get as this is a rare tire size. I'd try looking around the actual front tires see how much clearance has around, in particular near the lower spring seat plate. This metal plate runs pretty close to the tire
