Hello everyone,
I have a 1999 v-70 ... 2 days ago I plugged it in as it was very cold here and haven't drive the car for months. It took some work to get it started but she fired up and I pulled it into the trailer so I could haul it to my buddies shop. We let it sit overnig in his heated shop to thaw out a bit, I knew the car had the common Volvo fuel leak as the line was corroded and falling apart. We changed the fuel line, charged up the battery and now the car has no spark ..... it doesn't even try to fire up.
Checked coilpacks and none of them seem to be powering up ..... any suggestions would be very helpful.
Thank you
1999 v-70 suddenly no spark (weak battery, still cranked) Topic is solved
They take a common 12V from a relay so should be easy to fault trace
Search “1999 coil assignments “ to find info
If you can’t find it it’s also referenced in the maintenance record for my 1999 V70T5M nautical blue in that forum
Yes it will. ME7 needs a good battery to run the ECU and spark
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I didn't realised that low battery could cause this problem,untill i experienced it with my Citroen Xm last year....DIS ignition.
I thought that...if it is able to crank....it isn't battery although it cranked a bit slower than usual.
To cut the story....Battery eventually died i replaced it and never had the issue again.
I thought about this problem and i came to a conclusion that....that little power remained in the bad battery was enough to crank the engine,but wasn't enough for energizing main injection relay.
I also think that regular cap & rotor ignition wouldn't make this problem with low battery.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
OP is in alberta . Its so cold up there, internet packets take at least three days to make it to the network...
Seriously - Calgary Zoo pulled its penguins inside because nature only rates them for -40F/C
Problem solved with a new battery.loosenut wrote: 02 Jan 2018, 09:59 so did you fix the spark issue?
what fixed it?
are you still working on it?
Now just trying to figure out why my 4 ways and signal lights aren't working.
- 10 Replies
- 2080 Views
Last post by Rorgan
- 1981 Views
Last post by matthew1
- 818 Views
Last post by br1gold
- 16 Replies
- 1168 Views
Last post by Kokonradus
- 1247 Views
