First time posting, hope you can help.
Although this is our second Volvo, we are just starting to try and self-fix. We have moved from the land of plenty (Vancouver Island) to the frigid tundra (Ontario) where older Volvos are few and far between, as are the people that work on them. It's getting to be expensive so we are wanting to start doing whatever we can ourselves, it's fun to learn too!
So problems: last night it's -25C and the car wheezed a bit starting up, toughest it's been this winter so far. It does not seem to have a problem to warm up quickly and without issue, this is it's first ever winter and it's handling it like a champ (like I'm surprised!
Thank you!
A1: Transmission
124 - Mode selector faulty or short circuit to ground
A2: Fuel System
413 - EGR temp sensor signal faulty or missing
A3: ABS
141 - Faulty pedal sensor, shorted to ground or supply
142 - Faulty brake pedal switch, open or short
*The ABS lights have come on intermittently since we bought the car and different mechanics have said it's a common issue that is not serious. Would these both concern that?
A7: Combined Instrument
122 - Outside temp sensor open circuit or shorted to 12 volts
*I have noticed the temp sensor warning light in the dash comes on intermittently lately.
231 - Ventilation damper motor position sensor open circuit or shorted to 12 volts
