2006 V70XC Only warm heat when heater on high.
Bluegrassxc70
- Year and Model: 2006 xc70
Any idea how to diagnose a blend door or air door probes without pulling the heater core? I did see the motors, cams and linkages move when I had the pass side panels off. Seemed to be smooth, but I have no idea what the full range of Travel is supposed to be.
- Been thanked: 4071 times
Added year model to title per posting guidelines - this will also help others who can help you!
I’m pretty sure all P2s use full flow heater cores
Bluegrassxc70
Agree. I am 90% sure there is not a heater core control valve. Coolant is always flowing through it.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It's full flow as mentioned. At the end of this video I had a heater core cut open to check what's inside
Bluegrassxc70
I was about to buy a new heater core then went out and checked the inlet and outlet tube temps at the fire wall. When set to heat there is a large temp delta between the two. Then when set to cold, both tubes are hot. Seems like I am getting decent heat exchange.... but the air is still lukewarm at the vents. I would love to verify that my blend doors are fully operational. Can anyone tell me how to verify that all of the doors are in proper position when set to max heat? I am wondering if I have some bypas and mixing with other air....
velorider
- Year and Model: 2005 S60 T5
- Has thanked: 2 times
- Been thanked: 27 times
You can verify the bend motor and linkage is operating. Remove the side panel of the center console and kick panel under the drivers side. Just above the heater core you can see the linkage and motor for the bend door that directs air over the core. With the car running adjust the temp from low to high, you should see the linkage move. Then repeat on the passenger side.
Good luck
John
Good luck
John
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
If everything works when in High it's most likely the sensor in the ACC panel. When on High the sensor is bypassed and it runs a fixed program.
It's quite easily replaced with a standard off the shelf component and a bit of soldering if it is damaged in some way. It could also just be full of dust.
- oragex
At 32:00 you may see a bit how/which side linkage above the pedals is moving to activate the flaps inside
Alao make sure the cabintemp sensor near the passenger temp knob is clear of dust and doesn't look broken, with a flash light - do not touch it
- 13 Replies
- 1036 Views
Last post by surfbug1
- 3552 Views
Last post by 93ForMe
- 549 Views
Last post by Flyingdutchman
- 1991 Views
Last post by alschnertz
- 1817 Views
Last post by gstallons
