Vida 2014D Times out 12/31/2017 23:59 Topic is solved
- RickHaleParker
- Been thanked: 979 times
150 downloads of the patch and no comments. Is that a good thing?
Active
Past
Past
- Has thanked: 2200 times
Rick, at least I will take the time to say thanks! I decided to try this again and it worked fine. I am now back up and running with the Vida 2014A version. I think it may be I didn't reboot my computer as you tell us to do.
Truly appreciate the time you have put into this for us mere mortals!
Now have to try to get 2012A up and running as the repair instruction on that are much better than 2014.
- RickHaleParker
It does not surprise me, everything seems to be moving towards the Microsoft Information method ... technically correct but totally useless answers.
Install 2012A on a different machine?
Before I got Vida working on this Windows 10 Pro Workstation. I had 2014D on a separate machine with Windows 7 Pro. All my machines are networked together through my router. Whenever I need something off Vida, I would use Remote Connect to connect to the other machine and control Vida on the other from the Windows 10 Machine. I could even do it from my Windows 10 32bit 2GB tablet. I was a handy setup, if one used Bluetooth to connect to Dice. One took the Dice and the Tablet out to the car and run Vida over the WIFI network.
Active
Past
Past
That would be nice, but I take the computer with me and don't always have Wifi available or connection to my home system.
Like I said, it would be nice to be tech savvie, but it was never my strength and so I have to work within my capabilities.
Can't believe the 2012A version running in VM wear in XP mode can be any different to fix as it runs with a similar patch to operate it.
Thanks again,
Thanks again,
- RickHaleParker
Attach the 2012A patch to your next comment.
Active
Past
Past
Clotairee
- Year and Model: 2010
I have found a solution to this problem and download PATCH from http://blog.buyobdii.com/how-to-solve-v ... nt-log-in/
- RickHaleParker
Clotairee the King of the Franks? ... no clearly it is a bot .... kill it.
Active
Past
Past
- RickHaleParker
160 downloads of the 2099 patch and no complains.
Active
Past
Past
QUARKS40
- Year and Model: 2010 XC60
- Been thanked: 2 times
and Too few thanks.
THANK YOU!!!
2010 XC60 - P*, 3 Spoke steering wheel retro, Gearshift retro.
2001 S40 - 14T, BBTB, turbo back stainless DP, Upsolute, KW, 15mm rear sway, 17" Konig wheels, Custom Arctic Silver/Sonic Blue pearl paint, custom interior
- RickHaleParker
Your welcome Quarks40.
Downloads are now at 364.
I found a solution to the Internet Explorer 10 and 11 incompatibility in with Vida in Windows 7. There is a way to get Google Chrome to work with Vida in Windows 7, it works well and getting it set up is not a massive amount of work. There are still a few things I need to check. When I get them few thing checked and the write up polished, I'll start another topic in this form.
Active
Past
Past
- 8075 Views
Last post by jonesg
- 5239 Views
Last post by matthew1
- 4546 Views
Last post by Liliflower
- 10350 Views
Last post by nickbw898
- 2776 Views
Last post by xiami
