850 wagon base, turn, hazards and high beam blows fuse
RickHaleParker
Been thanked: 958 times
Re: 850 wagon base, turn, hazards and high beam blows fuse
Post by RickHaleParker »
So a FLIR style camera?
Yep! ... look for hot spots where there should be none.
Also the wire would be hotter on one side of the short, cooler on the other side if the short.
TerrDawg
Year and Model: 97' V90/98' S90
Has thanked: 7 times
Been thanked: 13 times
Post by TerrDawg »
Never thought of that but did put a relay in place of the fuse to see if it would reset ... worked once then got really really hot HAHAHA
Will look for a FLIR camera, where would I look first?
07' XC 70 Black/Lowered 136k mi
98' S90 blue 245k mi
98' S90 white super clean ! 274k mi
RickHaleParker
eBay, For example" https://www.ebay.com/itm/Thermal-Imagin ... OSwa-dWjxC~
Search for "Thermal Imaging"
TerrDawg
Post by TerrDawg »
UPDATE MARCH 18' since a $220 FLIR camera was a tad above my temporary disability budget.... I've continued the fix attempt, I found a jumper wire from the load side of one fuse to the power side of another, it was #20 and 21, high beam fuses. I removed it and found I have no right side high beam but I have blinkers now ... For about 5 to 15 minutes, then the fuse blows ... Again
I put it up for sale locally, gawd there are a lot of flakey people out here... Still have the vehicle and want to donate it for a tax deduction ... Would like to learn a way to find power draws on a circuit or a grounded circuit, I have a multi meter, if you could help great.
I've replaced so far, emergency flasher with internal relay on dash, high beam / turn signal on column, $40 dollars worth of bulbs so they can have the same amp draw, cleaned all sockets, replaced lens as necessary, chased wiring where obvious previous damage was on right front, chased possible grounded wires in wagon door from "stretching" ... Along with the fuse jumper issue just mentioned, I got nothing so far
Thanks,
Terry
Has thanked: 1501 times
Been thanked: 3812 times
Undoing someone else’s hacked wiring is really advanced stuff.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
abscate wrote: 28 Feb 2018, 20:44 Undoing someone else’s hacked wiring is really advanced stuff.
I’ve used a couple “alternative” expressions under the dash...
And then they get upset when there’s a labor charge involved
“Just to return it to stock!?!”. Good Times... 8)
