Head gasket job. Won't start
Kazbear
Year and Model: 2000 v70
Post by Kazbear »
2000 v70 turbo 2.4
Inexperienced, following several step by steps I could find.
Replaced head gasket, timing belt, water pump.
I was very careful to follow the steps. Keeping the timing in place, matching up the marks.
After putting it all back together, it acted, briefly, like it might want to start, but then quickly started to just make a whining noise when turning the ignition.
I am going to go back and triple check everything. But open to advice on what to look at next (starter?)
Afraid I may have missed something or didn't align something that may now have caused more damage.
Thanks for your understanding.
- Kaz
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Whining noise?
As in the crank turns and cams don't?
85 GLH, 367 whp
00 Insight, 72 mpg
Kazbear
Post by Kazbear »
After I heard that, I was reluctant to try again, but yes, that's what it seems like
Has thanked: 1502 times
Been thanked: 3817 times
Open up the timing cover and confirm the marks are still lining up. Good news is if you just cranked I doubt you did any damage if it did slip. Is battery good and up to snuff?
Kazbear
Post by Kazbear »
Ok. I will check that.
Battery seems good. Just in case, I did have it jumped to my other car to be sure...
Oh yeah - your 2000 has variable valve timing (CVVT) on the exhaust cam if I have that right. The gear on the cam towards the back of the car will have a big fattie can on it instead of just looking like a gear.
You have to align the timing marks differently on CVVT cars - were you on top of that issue? We can fix that if you weren't.
Kazbear
Post by Kazbear »
Yes, variable timing.
I rotated the crank pulley until the marks on the cams aligned with the notches on the timing cover before starting any work. When I put it all back, I made sure those aligned again.
I intend to recheck those marks as well as the mark on the crank pulley.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Did you keep the solid lifters in order?
Kazbear
Post by Kazbear »
Hmmm. No. I don't remember that step. Just to keep them in oil. Hydraulic lifters.
Ah. You have to rotate the cam past the marks by 90 degrees then come back to the marks with VVT. I’ll point you to the thread.
