1998-2000 V70 Tailgate Latch Autopsy 9485477 - Part number 8628197
Been thanked: 4068 times
Start notes.
1 This part 8628197 is for a two stage locking tailgate latch found on late 1998 and bastard P80s
2 The part number 9203955 is used on non-two stage locks - no more information known on that here.
3 This is an impressive Rube Goldberg device which I am sure has some Swedish Engineer in the nut house, giggling at the padded walls
It performs many functions
1. Interior tailgate release for heated rear seat
2.Child proof lock for (1)
3. Pull knob for trunk in tailgate trim
4 12V solenoid lock/unlock for use with cabin button and remote fob
5 Key lock and release for the cool V70s that still have a keyhole in the tailgate - this key allows you to lock, unlock and open the tailgate
6 Tailgate handle release above license plate
7 Tailgate shrimp gumbo, dice it, slice it, filet it, BBQ it..
Metal latch removed showing release and micro switch for tailgate open light - switch CLOSED in this position
Root cause of tailgate light on - broken plastic from latch internal to metal latch - difficult to repair
And the pictures....captions to come
Attach point of plunger
Crow view of the mechanism
more
more
Big white plastic mechanism is lock latch - solenoid, key, or plunger activated
The micro switch is closed with a plastic piece on the latch mechanism
In unlock the pin now DOES engage the lever
No part number on the steel part of the latch four tor screws omitted
View of the interior latch child lock lever
When moved, it moves the pin off the latch release
Attach point for the plunger lock
DrJammer
Year and Model: 2000 V70XC - 195k
Post by DrJammer »
What a fascinating post...but I fear I may need a translation? Did you figure out how to get rid of another cause of the 'tailgate open' light issue?
I have had my V70 rear pillar exposed for a year now trying to get the 'tailgate open' light off and the rear demister to operate. I am annoyed that butt splicing every wire has not fixed either.
I am more than willing to rip apart the tailgate latch mechanism to check 1 off the list. the double photos are a bit confusing, the tailgate panel has to be removed to get that part out?
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
I'm pretty sure the light is operated by a 12 V loop going through that micro switch, so you could check the connector above it but if the light is on the tailgate latch plastic is probably Broken, it's hard to imagine the wires breaking and putting 12V just in the right place
Replaced the latch with a new one from FCP. It's expensive, $160, as you have to buy the entire metal bracket, lock solenoid, and complete lock assembly in ABS.
You have to remove the tailgate interior cover (lock handle trim screws, trim, remove handle two m6 bolts) then pop not yon of cover down, remove cover)
You have four lock rods to attach
Easiest one is the interior tailgate lever..it just plunges down into the right most hole, no attachment
The lock plunger hooks into the white plastic hook on right part of lock solenoid
The key and outside handle both slip,into pin holes and then are retained by plastic keepers as shown..in the pic below the keeper is not yet clipped into the rod, it rotates 90 degrees to secure the rod
If the wire control rod doesn't reach, you are putting it in the wrong place!
You have to put the interior latch lever on last, as the lock today plunges down into the hole, then you secure the handle with two M6 bolts. If you don't pay attention , the lock rod can slip out of place if you let the handle move more than a cm or so.
I have a nice new crisp tailgate lick now, and I got back my rear light and alarm system operation too, and now have no lights on the dash!
Two failures.
Black plastic micro switch part broke off latch
Spring holder to return lock latch also broke, so spring was loose in metal latch
I can't see a way to open the metal latch up and effect repairs, it is welded closed. My PnP one lasted about two years but never really worked as well as the new one. I do think these things just wear out
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
PSST... I have a 3D printer and can print plastic parts in either ABS, PLA or other polymers in varied success.
You'd be surprised what people can do with 20 minutes and tinkercad of all things... In winter folks may find various ABS/PLA pieces on the bike that aren't there in the summer. Thus far mice don't like to eat the stuff...
Very nice. The plastic part that breaks on this part is buried inside the metal latch which I could not figure out how t open. It has swaged metal pins holding it together.
Do you want to put pins in the driveway this morning? 😀
Yuck.
wizechatmgr
If you feel like it, go for it. I will not be. Fat man tetris this morning took the life out of me...
:D :D :D
Let’s spare the forum the visuals
