IPD sale Volvo Parts
Did you know? 🤔
2003 S60 Fluctuating coolant level. (New coolant reservoir cap) Topic is solved
2001 - 2007 XC-70
Cookie-the-Swede
Year and Model: 2003 S60 2.5T AWD
Has thanked: 1 time
Been thanked: 4 times
United States of America
Cookie-the-Swede
Post by Cookie-the-Swede » Mon Jan 08, 2018 6:26 pm
So my coolant level starts off between MAX and MIN when the car is cold. After driving around for a few miles and the engine warms up the coolant level rises... completely filling the entire reservoir... and bubbling.
Then when the car cools back off, the level drops way back down to the MIN line. I notice that some coolant drips out (by the front passenger tire) until the engine cools back down, were it doesn't leak anymore.
Does anyone know what's going on here?
Thanks in advance.
velorider
Year and Model: 2005 S60 T5
Has thanked: 0
Been thanked: 5 times
velorider
Re: Fluctuating coolant level.
Post by velorider » Mon Jan 08, 2018 11:55 pm
I hope I'm wrong but this sounds like a leaking head gaskets. The air bubbles are exhaust gasses mixing with the coolant. There are machines that can test for exhaust gasses in the coolant, I would suggest getting the test done.
RickHaleParker
Has thanked: 3 times
Been thanked: 305 times
RickHaleParker
Post by RickHaleParker » Tue Jan 09, 2018 2:19 am
Bubbling and excessive expansion indicates you have a defective head gasket allowing gases to be pushed into the cooling system. There are chemical test that will check for gases in the cooling system. They go by the name "Combustion Gas Leak Tester Detector" or "Block Tester". The kits cost between $35 - $70 depending on now good of a shopper one is. A whole lot more for the type that pays too much for a Whistle.
Autozone has Block testers in their tool loan program. Your need to pay for the test fluid about $9.00 + tax. The test can be done in their parking lot so you may not need to place a deposit on the tool.
Pull the Oil cap off and look inside, pull the Oil dipstick. is the oil milky white?
Watch the exhaust when the engine is warm and running, does it have excessive steam, looks like white smoke.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
jonesg
Year and Model: 2004 V70
Has thanked: 2 times
Been thanked: 12 times
Wales
jonesg
Post by jonesg » Tue Jan 09, 2018 6:52 am
Napa block tester fluid ,$7.
See youtube videos
but the head gasket is leaking.
veenee
Year and Model: XC70 2007
Has thanked: 0
Been thanked: 0
Great Britain
veenee
Post by veenee » Tue Jan 09, 2018 7:21 am
I had exactly the same problem with Suzuki Jimny (yeah I know, different pair of shoes), and the garage guys were seriously puzzled as head gasket was fine.
I finally found on the internet that it might have been faulty radiator cap, I have replaced it and - bingo! - all was good!
The faulty one must have not keep the correct pressure any more...
Worth trying.
oragex
Year and Model: S60 2003
Has thanked: 78 times
Been thanked: 160 times
Canada
oragex
Post by oragex » Tue Jan 09, 2018 9:26 am
Please, before going into the head gasket territiry, replace the green cap with a new 'original' Volvo part. I believe Gates makes them for Volvo, check Ipd or Fcp sites. And wish people won't talk so quickly into head gaskets when it can simply be a faulty $10 part.
The cap must keep the pressure up to a certain ponit. When the gasket wears, it won't keep the pressure and the level will rinse inside the reservoir and will eventually leak outside it.
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue Jan 09, 2018 9:41 am
The boiling point of a liquid is the temperature at which its vapor pressure is equal to the pressure of the gas above it. The reason cooling systems run ~15 psi over atmosphere is to keep the gas pressure higher then the vapor pressure so the liquid does not boil.
Your correct, checking the cap would be good first step. I was trying to gather more information, first. That is why I suggested checking the color of the oil and the exhaust, the two don't cost anything.
These users thanked the author RickHaleParker for the post:
93SCMax
93SCMax
Year and Model: 2001 V70 T5
Has thanked: 5 times
Been thanked: 9 times
93SCMax
Post by 93SCMax » Tue Jan 09, 2018 2:03 pm
+1
I like that you are recommending a proactive approach that is simple and cheap to do.
jonesg
Wales
jonesg
Post by jonesg » Tue Jan 09, 2018 5:39 pm
Here's a simple test if you buy a new cap.
Get the block tester fluid from napa.
Pour a cup of fluid into a clear soda bottle.
Drill a hole in the old cap, run hose from cap to a bottle with block tester fluid. Submerge hose in fluid in the bottle.
As the air in the exp tank heats up the fluid in the bottle will begin to bubble, watch for the color change. That's a definitive test
Cookie-the-Swede
Has thanked: 1 time
Cookie-the-Swede
Post by Cookie-the-Swede » Sun Jan 14, 2018 10:15 am
There's no milky or discolored oil OR coolant. There's no white smoke coming from the tail pipe. It's not overheating.
I replaced the coolant reservoir cap and it isn't "boiling off" anymore. I still plan on replacing the radiator since it seems to have a small leak in the front right corner of the car.
