2001 V70 2.4T Rough growling when accelerating / Volvo code ECM-644A Topic is solved
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
US synthetic != actual synthetic though.
But regardless an oil change is due even if semi synthetic is fine for the engine.
Doubt that's part of the issue though.
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
So, this issue is still happening, and I'd like to get to the bottom of it.
The symptoms I'm currently seeing started on 10/30/2017 when I put the car back into service after replacing the oil seals. I had removed and reinstalled all of the timing components at that point. The symptoms include:
- Rough growling from engine during acceleration.
- Increased fuel consumption
- Relatively recent - on 12/26/2017 - Check engine light illuminated with OBDII code P0014 - B Camshaft Position Timing Over-Advanced or System Performance Bank 1 - If this was related to the work I did with the timing components on 10/30, not sure why it would take so long to get thrown.
I put the timeline up here if anyone cares to take a look and share your suggestions.
https://docs.google.com/document/d/15w1 ... sp=sharing
Cars I've owned:
Rattnalle
Post by Rattnalle »
Cam position codes can be delayed as far as I know so that does sound like it could be the issue. You'd need to trigger a specific set of circumstances for the engine to notice for real or something. The increased consumption also fits.
I'd still say the oil changes have nothing to do with it.
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Rattnalle wrote: 11 Jan 2018, 10:44 Cam position codes can be delayed as far as I know so that does sound like it could be the issue. You'd need to trigger a specific set of circumstances for the engine to notice for real or something. The increased consumption also fits.
Oil can effect the cvvt cams, mine kept showing sluggish reaction on vida.
Changed oil and filter and the code never came back. It WAS in desperate need, filter looked tragic.
jonesg
Post by jonesg »
prwood wrote: 11 Jan 2018, 10:36 So, this issue is still happening, and I'd like to get to the bottom of it.
Run the cvvt live test in vida, it pointed me to an oil flow problem , old filter and wrong oil.
You never know.
Been thanked: 4065 times
Yeah - that VIDA you just got up and running is going to pay for itself again. While I would have to dick around changing solenoids - you can go in and read out what they are doing and see if they are problem.
prwood
Post by prwood »
jonesg wrote: 11 Jan 2018, 11:51
You never know.
Ooh, will have to look into that. Thanks for the pointer.
Cars I've owned:
That line gave me a bad C++ flashback.
prwood
Post by prwood »
abscate wrote: 11 Jan 2018, 15:26
Glad I followed it up with a line about pointers!
Cars I've owned:
prwood wrote: 12 Jan 2018, 07:02
I just saw that and had that same pun-ishment.
Insert <std.io.torture>
