serpentine belt 2010 xc 70
raquette
Year and Model: 2010 xc90, 2007 xc70
Been thanked: 4 times
Post by raquette »
belt began smoking near the power steering pump area and screeches when turning the steering wheel. 96k miles.
the power steering is working and the pump pulley is turning.
looking for vid on replacing the belt. is it likely the power steering pump is beginning to fail?
raquette
Post by raquette »
correction this is a 2010 xc 90
mnmk
Year and Model: V70 2004
Post by mnmk »
I believe FCP has a video on their website in regards to serpentine belt replacement.
Not sure what vehicle though. I replaced mine on a 2004 V70 is was fairly straight forward.
Hope this helps.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
Double check that the alternator pulley isn't seized.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As above, remove the belt and turn all pulleys by hand - pump, alt and compressor plus tensioner. All should be easy and smooth to.turn. The p/s reservoir should have green fluid at level
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
A1 Auto, FCP and IPD all videos on serpentine replacement. The A1 Auto has one done on a V70.
Active
Past
raquette
Post by raquette »
ok thanks all!
Cookie-the-Swede
Year and Model: 2003 S60 2.5T AWD
Post by Cookie-the-Swede »
At the minimum, you are going to need to replace the belt. Possibly the tensioner, the power steering pump, or the alternator too.
All of these items are really easy DIY projects though.
