Rad Fan Turns On But Wont Crank Topic is solved
CadinVolvo11
- Year and Model: 1994 850 Turbo
I have a Volvo 850 turbo that I have just bought, and there seem to be some electrical issues. The battery isn't bringing any power to the car so when hooking it up to a charger the Rad fan immediately turns on, and the AC keeps turning on and off regardless if it's turned on or off. The last thing is that when I turn the key over there is no ignition at all, and the dash seems to dim. I have done some research and have only seen one post about it being the ECU sensor.
That sounds like a mess of electrical problems - many more than one. Do you have any history on it?
CadinVolvo11
The guy I got it off of gave me all the past maintenance inspections and what not, but nothing electrical ever came up. It has also been sitting for about a year. I am thinking of running codes on it tonight
- RickHaleParker
- Been thanked: 979 times
Been sitting a year without a battery maintainer?
Active
Past
Past
CadinVolvo11
Yes without a battery maintainer. Would that have shorted the system out?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Bring that battery to a car parts store in the morning - should charge and be able to be tested by afternoon. Odds are the battery is toast...
CadinVolvo11
I have tried new batteries in the car as well
- RickHaleParker
No but Skloon is correct. It could be wire damage due to Mice. The plastic insulation on the wiring is a soybean based plastic. In times of famine, mice will try to utilize the plastic as a food source. A thorough wire harness inspection would be a good start.
Active
Past
Past
- Has thanked: 2200 times
So, I take it was chewed wires somewhere? It would be good to know what was damaged.
- 1144 Views
Last post by wizechatmgr
- 1007 Views
Last post by lewiskoolman72
- 2519 Views
Last post by RickHaleParker
- 730 Views
Last post by whilst
- 938 Views
Last post by jenkinskg
