Hi everyone!
I have a 2007 XC70 (130k miles) that repeatedly blows the 15A fuel pump fuse 10-15 seconds after starting. VIDA says ECM291-D (Fuel pump control module -- Signal too low) and CEM-3F90 (Fuel pump relay open circuit or shorted to ground); think those codes more or less mean that the fuse blew.
I am guessing it’s a failing fuel pump that is starting to lock up - but I want to be sure before I drop $200. Are there any other components that are prone to fail on these cars, and cause a similar issue?
The PEM looked fine (opened it up, no corrosion on connector or inside). It is mounted in the trunk, so no serious corrosion issues like the earlier models.
The only other issue that popped up is a “Low Battery” message - curious, since the car was not cranked over excessively in between failures. Could a bad alternator or battery contribute to any of this in some convoluted way?
Any guidance on other things I should check before ordering the pump? Any other parts I should consider replacing “while I’m in there”?
All advice is greatly appreciated!
Thanks
Michael
2007 XC70 Fuel pump fuse repeatedly blows
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
$200 for a pump ?,mtd240 wrote: 16 Jan 2018, 17:21 Hi everyone!
Thanks
Michael
I would look at swapping the motor only.
Did that on my old Volvo , $55.
Pump motor was korean made.
A.C. Delco with a Volvo sticker.
Bought replacement at autozone.
- RickHaleParker
- Been thanked: 979 times
Yes, electronics can get sensitive over the power supply voltages. Use a Multimeter to see if the Alternator is charging. Take the battery in to Autozone for a free battery test. Hold off on ordering parts until you know the battery and charging system is in good condition. It is possible that the pump is drawing more current due to low battery voltage.
Active
Past
Past
mtd240
Battery tested fine (Advance Auto). Alternator is pushing 100-150A depending on how many accessories I turn on (headlights, HVAC, heated seats, defroster, etc.). That seems reasonable. Car ran fine yesterday. I am still thinking it's the fuel pump. Maybe it got jolted around on the tow truck enough to give it a few dying breaths.
Gone:
Gone:
Im in the middle of diagnosing fuel delivery problems on my 2005 which I ***think*** is pretty close to your 2007 in design.
There is a 40Amp fuse under the engine compartment that is worth checking for corrosion and junk - you have to lift the fuse panel to access it - after disconnecting battery and the large two red positive feeds to the fuse box (M8 nut)
- RickHaleParker
There are two fuel pumps one is called the Fuel Pump the other is called the Feed Pump, Ejector.
One is located on the Right Fuel Level Sender.
The other is located on the Left Fuel level Sender.
Both pumps and the Fuel Pump Control Module (PEM) are on that 15A fuse that is blowing.
Active
Past
Past
mtd240
I couldn't get the fuse panel out of the black box it is clipped into. But, there is definitely an electrical issue of some sort. While the car is running, the interior lights and headlights flicker. One of the low beam bulbs burnt out too. It idles at a little under 700 RPM now, too.abscate wrote: 19 Jan 2018, 07:13 Im in the middle of diagnosing fuel delivery problems on my 2005 which I ***think*** is pretty close to your 2007 in design.
Alternator outputs good amperage, voltage is at 14.5V while running (at the battery - 14.6V at the positive post on the fuse panel), and the battery tested fine. AC voltage at idle is 0.05V.
No check engine light either.
Any other hints?
Gone:
Gone:
You have to:
Disconnect battery negative terminal
Remove 4 torx screws
Remove the M8 nut from the two fat red wires feeding the fuse box.
Then the underside fuses can be accessed.
the 40 amp fuse also feeds the right headlight and fuel pump..is that the one that is Burned out?
QUARKS40
- Year and Model: 2010 XC60
- Been thanked: 2 times
Attached is something I found regarding changing the intank fuel pump on a 40. I know, not the same, exactly, but this worked on a 2000 V70 I did a two years back, maybe this will give you an idea on how to do it on yours.jonesg wrote: 16 Jan 2018, 21:07 $200 for a pump ?,
EDIT: how is the fuel filter???
and .... Wasn't there a tech bulletin about the fuel pump relay being wonky?
volvo fuel pump.pdf- (1.13 MiB) Downloaded 440 times
2010 XC60 - P*, 3 Spoke steering wheel retro, Gearshift retro.
2001 S40 - 14T, BBTB, turbo back stainless DP, Upsolute, KW, 15mm rear sway, 17" Konig wheels, Custom Arctic Silver/Sonic Blue pearl paint, custom interior
mtd240
There aren't any torx screws on the '07 fuse panel - it is held in with a bunch of clips. Even after disengaging the clips, though, the fuse panel won't lift out of the plastic enclosure. Feels like all the wires are attached to the enclosure somehow - I don't want to break any wires/connections by yanking on it. Guess I'll give it another try today.abscate wrote: 19 Jan 2018, 20:24 You have to:
And yep - it's the right headlight that went out. How could a finnicky fuse cause that?
Gone:
Gone:
- 10 Replies
- 4787 Views
Last post by dpayne20
- 8766 Views
Last post by dcm0123
- 13 Replies
- 5055 Views
Last post by MadeInJapan
- 1198 Views
Last post by wizechatmgr
- 1546 Views
Last post by TerrDawg
