pins for fuel door bracket oops!
volvomadness
Year and Model: v70 2003
Been thanked: 9 times
Post by volvomadness »
Had the fuel door bracket on a table with the pins. The table was cleaned off and pins are no where in sight. Has anyone found a place or way I can replace them. Home Depot? or other
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Unless somebody got real bored, I doubt anybody took the time to locate replacement pins. The fuel door hinge assembly is $6.00 on Ebay. If I was in your shoes and need it done today, I would locate nails the right diameter then cut pins out of the nails.
Active
Past
kcb203
Year and Model: 2005 XC70
Post by kcb203 »
Can you pull the used pins out of the old bracket? I did that for one of the four when I replaced mine because I was missing one.
