AC motor solenoid bypass possible? - 2004 XC90
Nevilled
Year and Model: 2004 XC90 D5
Post by Nevilled »
Hi Folks
Great site! My Aircon fan has stopped working and I suspect that its the solenoid/resister that has blown. Is there a way to bypass this unit, even if i have to install a toggle switch?
Reason: improved title, added tag
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Global stickyed temporarily - anyone have any suggestions?
Also -> Amazon link
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
The fan speed controller is just a current limiter on the ground side of the fan. If you ground the fan's negative terminal, it will run full blast. If you place a resistor between the fan's negative terminal and ground it will run at a slower speed. You should use wire and resistors that can carry the current of the fan without burning up and burning down your Volvo.
Active
Past
