05 S60 2.5T Hissing Sound, Passenger side intake Topic is solved
allan4187
- Year and Model: 2005 s60, 2001 s80
When the car is running, I can hear a sucking or hissing sounds coming from somewhere, I think, underneath the intake manifold near the power steering pump. Is there a common valve or hose that fails there? It is very hard to pinpoint and/or get to that area to check closer.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
At warm idle, pull the dipstick and/or undo the oil filling cap. Also watch for fumes out of the dipstick tube. Could be a blocked PCV, urgent repair so you don't blow costly engine seals. May google up for details and don't forget to inspect the oil passage to the oil pan.
- Been thanked: 4064 times
Banjo bolt with a hard plastic vacuum line under intake manifold, cylinder 1
Could Also be broken PCV big hose
- oragex
Is it continuous and at idle too? Can you record the noise on Youtube?
allan4187
Continuous at idle. Sort of goes away when revved up, but that could be because the engine sound drowns it out.oragex wrote: 13 Jan 2018, 19:17 Is it continuous and at idle too? Can you record the noise on Youtube?
thanks I'll check those out. Sounds about right.abscate wrote: 13 Jan 2018, 17:29 Banjo bolt with a hard plastic vacuum line under intake manifold, cylinder 1
allan4187
Thanks abscate. It was the single small line that came off the banjo bolt that had came loose from where it connected to the can. Didn't improve any of my other issues, but at least that hissing went away!abscate wrote: 13 Jan 2018, 17:29 Banjo bolt with a hard plastic vacuum line under intake manifold, cylinder 1
Outstanding Red Team.
It was either that or a missing Cobra....
- 709 Views
Last post by cgsnipe
- 1098 Views
Last post by amst76
- 22 Replies
- 5836 Views
Last post by HobbesMRH
- 1608 Views
Last post by FlyingVolvo
- 1264 Views
Last post by hristijanc
