Big oil consumption - PCV related? B5204T5 (2.0T 2006)
Been thanked: 504 times
Post by cn90 »
If you don't want to drop the pan, the clean the lower port as you said with a very stiff wire.
Then hook up a hose and blow to see if you can hear bubbles.
I discussed that in the 1998 S70 GLT PCV thread, which I wrote about 6 years ago.
DIY: 1998 Volvo S70 GLT PCV Mod: no more smoking dipstick!
viewtopic.php?t=53448
Post by cn90 »
chrism wrote: 21 Jan 2018, 11:57 Is it really necessary to drop the pan or is it OK to just spray a goodly amount of carb cleaner through the port and out the pan drain?
- An easy approach is to clean it with a stiff wire. The n use a hose and syringe to suck as much debris as possible.
Any gunk that goes down stay in the pan (usually very small amount.
- I read somewhere that there is an easy way to clean the sump w/o removing it. Something like this:
1. Drain the old oil.
2. Fill the sump via the dipstick tube with things like Seafoam or "Berryman", about 5-6 qts. Let it sit there to dissolve gunk. During this step, do NOT start engine.
3. Drain the junk.
4. Fill with cheap oil, leave the oil filter alone for now.
5. Run the engine for a few minutes.
6. Change oil using synthetic + new filter.
I may be wrong b/c I read this somewhere else...
READ the post by 2015_PSD:
https://www.bobistheoilguy.com/forums/u ... een_by_soa
