IPD sale Volvo Parts
Flywheel installation, volvo 850
Seany27
Year and Model: 1995 volvo 850
Has thanked: 3 times
Great Britain
Re: Flywheel installation, Volvo 850
Post by Seany27 » Mon Jan 22, 2018 9:39 am
I did get 2 codes on port a2, 535 turbo regulator valve fault, if that's boost controller, I've put a manual one in. And 514, engine cooling fan faulty or at half speed, I know both of my fans worked, everything was stored neatly
Seany27
Great Britain
Post by Seany27 » Tue Jan 23, 2018 6:11 am
I've just took all the auto stuff off one my harnesses, saw it was sharing positive and ground wires,, let's see if this makes a difference
Year and Model: Many Volvos
Been thanked: 28 times
United States of America
Post by Ozark Lee » Wed Jan 24, 2018 10:43 am
Does the IAC valve buzz when you put the key in position II?
The master fuel system relay, which is mounted on the radiator shroud, provides voltage for the injectors and also the IAC valve. If the IAC valve isn't buzzing it is a dead giveaway.
Usually the relay is OK but the way the wiring harness plugs in it is unprotected and the harness and the connector can be problematic.
'99 V70XC - Nautic Blue
Seany27
Great Britain
Post by Seany27 » Wed Jan 24, 2018 10:46 am
None of them buzz, got 3, I know 1 works/ worked, more problems now as I've stripped the auto stuff off the harness, and now doesn't spark. Maybe one day things will go right
Who is online
Users browsing this forum: Bigjim9254, WhatAmIDoing and 51 guests
