Thats a dead, dead, dead battery
P2 cars do not like low voltage, so don't do anything until you get a good battery in there.
2007 XC70 Fuel pump fuse repeatedly blows
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
Issue(s) solved!
Replaced the battery (side mission I guess - didn't fix the fuel issue).
Went back in to pull the fuel pump out. Pulled everything - found that the fuel hose had kinked in multiple places. Starved the fuel pump (hence no pressure).
I reinstalled it all - much more carefully (and oddly enough, much more quickly) than the first time. Didn't worry about clipping the secondary suction line to the second level sender - just plugged it in and ran the tiny messenger wire I used up and out of the tank. Should keep it from moving too much, and it prevented me from having to twist and turn that suction line to get it clipped in the right orientation (more chances for kinking).
Car started on the first try. Lesson learned (again): I should always assume that broken things are my fault!
Also - the intermittent fuel level sender signal was a separate issue. Not sure how this happened, but I taped it up and didn't bolt the access plate down too hard this time.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
- RickHaleParker
- Been thanked: 978 times
Looks like you twisted the hose on instead of pushing it on.
Active
Past
Past
mtd240
Not sure what you mean? The picture just shows where one of the wires (white - goes to the PEM) was shorting on the fuel pump access cover.RickHaleParker wrote: 26 Jan 2018, 16:43 Looks like you twisted the hose on instead of pushing it on.
Drove it awhile today, then the "Power System Service Urgent" light came on (codes CEM-1C06 and CEM-1C08). Guess my new alternator (Bosch 140A) was faulty out of the box, or running it for 10 minutes with a bad battery killed it (shouldn't have). New one is on the way. The fault only happens when the car has warmed up for awhile - I went out and restarted it after an hour or so, and it took ~15 minutes of idling for the alternator to stop working again. It passes the VIDA "Quick test" when cool, and fails when hot.
Hopefully this isn't due to some other fault in the electronics.
Gone:
Gone:
Check those cables for either resistance ( by voltage drop) or heat (IR gun) to see if they are a problem.
mtd240
Voltage drop from battery positive terminal to alternator B+ post: 0.124V (max). Drops as the car warms up.abscate wrote: 27 Jan 2018, 12:39 Check those cables for either resistance ( by voltage drop) or heat (IR gun) to see if they are a problem.
Voltage drop from battery negative terminal to ground in engine bay: 0.1V.
The alternator output zeroes out as soon as I put a high load (e.g., just the headlights, or just the rear defroster) on the system, and doesn't return to normal even after shutting off the loads that were added.
Gone:
Gone:
- RickHaleParker
Belt condition and belt tensioner can cause the CEM-1C08.
Have you had a battery charger on it lately, too high of charge voltage can cause CEM-1C06.
Active
Past
Past
mtd240
These codes are only from driving the car around for around an hour after clearing all DTCs - no jump starting or battery charging.RickHaleParker wrote: 27 Jan 2018, 13:36 Belt condition and belt tensioner can cause the CEM-1C08.
The belt tensioner bearing has a little bit of play in it (no noise) and the belt itself looks fine (no cracking). Not sure how that would cause the alternator output to suddenly zero out after warming up for a while? Steering and A/C work fine after the alternator voltage drops.
Gone:
Gone:
- 10 Replies
- 4785 Views
Last post by dpayne20
- 8764 Views
Last post by dcm0123
- 13 Replies
- 5055 Views
Last post by MadeInJapan
- 1194 Views
Last post by wizechatmgr
- 1545 Views
Last post by TerrDawg
