2000 V70XC Poor MPG and hard start- Fuel pressure?
Kara503
Year and Model: 1996 850 Plat R-Swap
Has thanked: 17 times
Been thanked: 6 times
Post by Kara503 »
Currently troubleshooting a few issues on my newest find, a 2000 V70XC. Picked it up for a $900 with only 130k miles, with a recently rebuilt Angle gear and turbo. Was puking oil- found the intake front cam seal was completely missing! Good times.
Anyway- It stumbles on start and gets a paltry 17 MPG. Fuel delivery is next on my list of possibilities. Priming the system several times before starting helps, but doesn't completely eliminate the hard/ stumble start. No CEL. At the valve on the rail, here is what I am getting-
On prime- Immediate 50 or 60 PSI. Priming several times brings it up to 60.
Running- rapidly jumps through range of 40-60, occasionally holds steady at 55-60, then returns to erratic pressures that fluctuate so fast there is no single reading, just a range.
On shutdown, pressure steadily drops to 40 PSI over the course of 10-15 minutes. After that, it goes down very slowly- haven't let it sit more than 30 minutes, and in that time it only went down another 2 PSI.
My guess is I have a fuel pump that is starting to go out. I'm in the process of replacing the fuel filter to see if that helps. Next I will be checking the regulator and check valve before...... choosing between cutting the floor of my car or dropping the whole rear to access the pump. :evil:
Any suggestions? Am I jumping too far ahead? Thanks!
96 855 Platinum- Elsa
98 V70R- Goose
06 S40 NA- Hilda
02 VW Jetta TDI wagon- Dizzy
wlkstout
Year and Model: 1998 V70 na
Has thanked: 3 times
Post by wlkstout »
I would check the pressure regulator before cutting a hole. Not sure where yours is but on my 98 v70na it is at the fuel filter area just in front of the fuel tank. It has a diaphragm and is vacuum controlled. It could have failed or have a vacuum leak. With the erratic values maybe a possibility.
1998 V70 SW 2.4l na
1992 Olds Cutlass Supreme 3.1l
1994 Dodge Dakota 3.9l
1993 GMC 1500 5.7l
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Take a lot of the guesswork out, get Vida 2014D + DiCE. It will pay for itself in time saved alone.
Active
Past
Kara503
Post by Kara503 »
Good idea wlk. Rick- What kind of setup do you have/ where did you get it? I have done some looking at VIDA/DICE but am unsure what to buy.
98 V70R- Goose
06 S40 NA- Hilda
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
That fuel pressure is pretty spot on for a turbo
Low mpg can be quite a long list of things. Even just a clogged PCV (thin k blown cam seal) can bring it down. I'd rather take the time and test everything before replacing parts, or at least replace with used parts so it doesn't get too expensive.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
How do you drive the car for that long to calculate mpg without front cam seal???
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Kara503
Post by Kara503 »
I bought the car 2 months ago. Drove it to my house in that condition, and the parked it until I had time to replace the PCV system, clean the throttle body, replace all of the cam seals, and replaced the timing belt. :)
oragex- I've already replaced the plugs, tried a known good set of coils, and done an upper intake seafoam treatment as well as a few injector cleaners into the tank. I checked the timing after I did the belt, and checked it about 2 weeks ago and all the marks line up too so it isn't that. I feel I did a pretty thorough job on the PCV too- Cleaned all the block passages and replaced all of the piping. I'm unsure where to turn if it is not fuel related, but then again I have only been trying honestly to fix cars for about 6 months now :)
98 V70R- Goose
06 S40 NA- Hilda
oragex
Post by oragex »
Removing and sending the injectors for an ultrasonic bath cleaning is a good idea at high miles - Ebay or even nearby shops who deal with truck diesel engines which need injector cleaning on a regular basis.
Other areas would be the fuel filter, thermostat stuck wide open, non binding brakes, no vacuum leaks, good engine sensors, not too old front O2 sensor, not clogged catalytic converter, no loss of compression, etc. On top of what others have already mentioned above.
