Stereo Lighting Half Out
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Thanks for all the info. I doubt it was enough force to crack the circuit board. I'll pull the stereo and crack it open as soon as I have a chance. Thanks!
Knows enough to be dangerous
- Has thanked: 312 times
- Been thanked: 818 times
The bulbs everyone has referred too so far are great for the dash switches, but not what I buy for the radio bulbs. Save yourself the minor headache, buy the radio bulbs that are already wired up in the correct base: https://www.mouser.com/ProductDetail/560-CNW123?
wlkstout
- Year and Model: 1998 V70 na
- Has thanked: 3 times
Thanks for sharing the part number. I am going to be swapping bulbs in the hvac and radio later this week. I ordered the 7219's from Amazon and was going to try and swap the bulbs on the black units but just called the local honda dealer and they have them for 2 bucks and change. After i pull them and see if its worth the aggregation, i may just swap those out being so cheap.kahl wrote: 29 Jan 2018, 12:27 image.jpgI used these Honda bulbs. Worked perfect. I have 5 left. PM me and I will send them to you.
1998 V70 SW 2.4l na
1992 Olds Cutlass Supreme 3.1l
1994 Dodge Dakota 3.9l
1993 GMC 1500 5.7l
1993 GMC 1500 5.7l
Methinks you don't want to mess with 7219's in the radio bulbs ... let us know!
- WhatAmIDoing
Update: Finally got around to replacing the bulbs. It was pretty easy. Special thanks to kahl for supplying me with his leftover Honda bulbs. Now my whole stereo lights up. I feel like the Honda bulbs are slightly dimmer than the original Volvo bulbs, but at least now I can see all the buttons at night.
When pulling the stereo, discovered it's not original. It's a remanufactured unit from 2006. Also noticed these extra plugs that were not plugged in. What are they for (circled in red)? All the others were plugged in.
- Has thanked: 2210 times
Do you have an amplifier under the passenger seat? Black box held down with 2 bolts on the LH side front floor under the passenger seat? Was the car fitted with a CD multichanger?
- WhatAmIDoing
I will check for an amplifier in the morning. The car shipped with a CD changer, not sure it still has one (weren't these fitted somewhere in the boot?). I still use cassettes mostly.scot850 wrote: 23 Feb 2018, 23:41 Do you have an amplifier under the passenger seat? Black box held down with 2 bolts on the LH side front floor under the passenger seat? Was the car fitted with a CD multichanger?
- raivis_rsn
- Year and Model: V70 1999 TDI
- Been thanked: 7 times
One looks like sub-antenna plug for diversity antenna system but SC-816 doesn't support that. Large 6pin plug is probably one end of extender cable for amplifier. But I'm not sure about third plug. Probably CD changer emulator for USB media or actual CD changer.
- WhatAmIDoing
There's definitely a spot for the upper jack circled in red to plug in, but I don't think the other 2 go anywhere.
- 9736 Views
Last post by zoli440
- 748 Views
Last post by sandyegg
- 796 Views
Last post by difflock54
- 1685 Views
Last post by heatherw
- 18 Replies
- 5060 Views
Last post by Teddy1975
