oil flush and magnetic drain plugs
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Tomca
Year and Model: 740, 1990
Post by Tomca »
Hello,
I have a 1990 Volvo 740 GLE, B200E engine, MK47 II manual transmission. I decided to flush the manual transmission oil and the rear differential oil. I thought I could also do a replacement of the drain plugs to magnetic ones.
- What is your opinion about this? Does it worth?
- I could find drain plug for the transmission (e.g. http://www.cvi-automotive.se/en/article ... drain-plug), however, I could not find magnetic drain plug for the rear diff. One page claimed that they are the same, M18x1.5x12 (http://www.drainplugmagnets.com/volvo.php , text at the blue screw). Is this true that the same plug can be used for the rear diff?
12 years before, I already flushed these oils. At that time, according to Haynes Volvo Manual and other books, I used W90 hypoid gear oil for the rear diff and ATF-F oil for the manual transmission.
Now, I checked some online catalogues, and they recommended 80W90 oil for the rear diff and 10W60 oil for the transmission.
- What is your opinion? What should I use?
Thank you for your answers in advance,
Tamas
Tomca
Post by Tomca »
Sorry, whatever I do, the first letter becomes capital V in volvo.php in the second link and the link becomes broken...
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Tomca wrote: 30 Jan 2018, 11:39What should I use?
Volvo owner's manuals: Read up on any Volvo, from any year.
If differential has limited slip, a special hypoid oil is used. I use what ever an OEM says should be used, or its updated oil.
Tomca
Post by Tomca »
Thank you. Just like my old books, it recommends ATF-F.
