Amplifier - How Volvo adds it 9452029
Volvo OEM Amp Install in a 1998 V70
LOB
- Year and Model: 855 GLT 2.5T
- Has thanked: 10 times
- Been thanked: 16 times
The Pioneer active subwoofer manual tells me to connect the + to the fuse box. Can't I use the (yellow) accessory outlet above the brake pedal? It's supposed to deliver 20A and the subwoofer only uses a maximum of 7A. Any reason Pioneer doesn't mention this as an option since most cars (?) have an accessory outlet?
- nathanso
- Year and Model: 1998 V70 T5M
- Been thanked: 2 times
Some notes on installing the Volvo 9452029 amplifier in a 1998 V70. Easy job once you know about the hidden features and have the right parts. The carpet on the transmission tunnel pulled right out from under the various trim pieces and refit just as easily. As an audiophile, I can tell you that the sonic benefit is well worth the effort. If you have never removed your front seats go on Youtube and learn how to not trigger the side airbag before proceeding!
1998 V70 T5M
- Has thanked: 316 times
- Been thanked: 531 times
I actually never secured mine after installing, it's just stayed in place. Good to now about the bolt holes under the carpet... I'll have to punch those out and bolt it down!
I must say, your carpet is very clean!
- Been thanked: 4069 times
I can hear you over here in Mosconenathanso wrote: 31 Jan 2018, 16:00 Some notes on installing the Volvo 9452029 amplifier in a 1998 V70. Easy job once you know about the hidden features and have the right parts. The carpet on the transmission tunnel pulled right out from under the various trim pieces and refit just as easily. As an audiophile, I can tell you that the sonic benefit is well worth the effort. If you have never removed your front seats go on Youtube and learn how to not trigger the side airbag before proceeding!
What’s the red wire running by the seat? Is that the heated third seat option ?
Did we finally find a car with that option!?!?abscate wrote: 01 Feb 2018, 09:00 What’s the red wire running by the seat? Is that the heated third seat option ?
- nathanso
Red wire charges my cell phone.abscate wrote: 01 Feb 2018, 09:00What’s the red wire running by the seat? Is that the heated third seat option ?
1998 V70 T5M
Sssshhhh. Everyone will want one if we let the cat out of the bag.bmdubya1198 wrote: 01 Feb 2018, 09:29Did we finally find a car with that option!?!?abscate wrote: 01 Feb 2018, 09:00 What’s the red wire running by the seat? Is that the heated third seat option ?
- nathanso
Here's a 9452029 amp with wiring harness for $50 is anyone wants one: https://www.ebay.com/itm/223107210209 (no affil.)
1998 V70 T5M
Nikolaech
- Year and Model: Volvo 850 93
- Has thanked: 15 times
With my own hands. Wiring harness diagram 9452030
connector P80!
Almost done.
Download the scheme in good quality. https://drive.google.com/file/d/1-MmOXi ... share_link
connector P80!
Almost done.
- 752 Views
Last post by Peteseagull
- 864 Views
Last post by erikv11
- 7033 Views
- 1020 Views
Last post by LOB
- 1965 Views
Last post by kridronoa5
