Low cabin heat? Try this first
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Scotty Kilmer shows what to do when the air coming out of the vents is not hot enough
Has thanked: 2200 times
Been thanked: 1852 times
Why would a core clog? I have never had this happen in any Volvo in 40+ years. This would only occur when cheapskates use high calcium tap water instead of de-ionised water. Serves them right for Volvo abuse!
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
If the car has rubber heater hoses, flip the hoses to the heater core periodically as preventive maintenance.
Active
Past
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
scot850 wrote: 02 Feb 2018, 10:35 Why would a core clog? I have never had this happen in any Volvo in 40+ years. This would only occur when cheapskates use high calcium tap water instead of de-ionised water. Serves them right for Volvo abuse!
I could see someone using radiator sealant as a potential hazard as well.
I've always changed the coolant when I've bought the cars and usually it has looked terrible but with no other issues that I've noticed.
oragex
Post by oragex »
Wrong coolant from a shady mechanic, or a mixture of wrong coolants. Or indeed water from the hose mixed with coolant (looks like the case in the video, see the deposits at the hose connection at the firewall)
Been thanked: 4065 times
That has to be one of the most annoying videos ever.
Also like how his heater core hoses are blowing coolant after he replaces them.
Rattnalle
Post by Rattnalle »
oragex wrote: 02 Feb 2018, 12:24 Wrong coolant from a shady mechanic, or a mixture of wrong coolants. Or indeed water from the hose mixed with coolant (looks like the case in the video, see the deposits at the hose connection at the firewall)
VIDA pretty much says "You can use tap water if it fulfills *detailed criteria*. If unsure, don't." I'd say that means "no" for most people :)
It's hard to use a "wrong" coolant but mixing different kinds can sure be nasty..
RickHaleParker
At $1.00 per gallon, distilled water is a cheap insurance policy.
Active
Past
Rattnalle
Post by Rattnalle »
RickHaleParker wrote: 02 Feb 2018, 12:50 "You can use tap water if it fulfills *detailed criteria*. If unsure, don't."
It is indeed. I'd say even ready to use coolant is quite cheap insurance if the alternative is trouble with the cooling system.
oragex
Post by oragex »
Rattnalle wrote: 02 Feb 2018, 12:47
Correct. Sounds like VIDA is expecting owners to take the tap water for analysis :? Unless perhaps living on Beverly Hills (just a wild guess), tap water is always more or less hard and it will leave deposits. Suffice to look inside the bathroom near the sink faucets, for white traces of lime (calcium) deposits. Wouldn't want these near my water pump 8)
