Scotty Kilmer shows what to do when the air coming out of the vents is not hot enough
Low cabin heat? Try this first
- Has thanked: 2199 times
Why would a core clog? I have never had this happen in any Volvo in 40+ years. This would only occur when cheapskates use high calcium tap water instead of de-ionised water. Serves them right for Volvo abuse!
- RickHaleParker
- Been thanked: 977 times
If the car has rubber heater hoses, flip the hoses to the heater core periodically as preventive maintenance.
Active
Past
Past
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I could see someone using radiator sealant as a potential hazard as well.scot850 wrote: 02 Feb 2018, 10:35 Why would a core clog? I have never had this happen in any Volvo in 40+ years. This would only occur when cheapskates use high calcium tap water instead of de-ionised water. Serves them right for Volvo abuse!
I've always changed the coolant when I've bought the cars and usually it has looked terrible but with no other issues that I've noticed.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Wrong coolant from a shady mechanic, or a mixture of wrong coolants. Or indeed water from the hose mixed with coolant (looks like the case in the video, see the deposits at the hose connection at the firewall)
That has to be one of the most annoying videos ever.
Also like how his heater core hoses are blowing coolant after he replaces them.
- Rattnalle
VIDA pretty much says "You can use tap water if it fulfills *detailed criteria*. If unsure, don't." I'd say that means "no" for most peopleoragex wrote: 02 Feb 2018, 12:24 Wrong coolant from a shady mechanic, or a mixture of wrong coolants. Or indeed water from the hose mixed with coolant (looks like the case in the video, see the deposits at the hose connection at the firewall)
It's hard to use a "wrong" coolant but mixing different kinds can sure be nasty..
- RickHaleParker
At $1.00 per gallon, distilled water is a cheap insurance policy.
Active
Past
Past
- Rattnalle
It is indeed. I'd say even ready to use coolant is quite cheap insurance if the alternative is trouble with the cooling system.RickHaleParker wrote: 02 Feb 2018, 12:50 "You can use tap water if it fulfills *detailed criteria*. If unsure, don't."
- oragex
Correct. Sounds like VIDA is expecting owners to take the tap water for analysisRattnalle wrote: 02 Feb 2018, 12:47VIDA pretty much says "You can use tap water if it fulfills *detailed criteria*. If unsure, don't." I'd say that means "no" for most peopleoragex wrote: 02 Feb 2018, 12:24 Wrong coolant from a shady mechanic, or a mixture of wrong coolants. Or indeed water from the hose mixed with coolant (looks like the case in the video, see the deposits at the hose connection at the firewall)![]()
- 21 Replies
- 5518 Views
Last post by oragex
- 733 Views
Last post by Kach
- 581 Views
Last post by MarcM
- 26 Replies
- 5462 Views
Last post by dejanaleksov
- 26 Replies
- 4203 Views
