How to get oil out of Spark Plug Cylinders
- Been thanked: 4071 times
How do you get that good engine oil out of the paper towels to use in your Toyota?
ir637113
- Year and Model: 94 850 NA Wagon
- Has thanked: 12 times
Finally got around to this over the weekend. A+ on the pipettes. Would definitely recommend it.prwood wrote: 27 Nov 2017, 07:03 I've used a turkey baster to suck oil out of spark plug wells. I've also used small plastic pipettes to suck oil from places where the turkey baster wouldn't fit.
- RickHaleParker
- Been thanked: 980 times
Take the top off a spray bottle and pump the oil out to a paper towel or into the bottle.
Active
Past
Past
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
That is quite a clever solution. A syringe and a piece of clear tubing always worked for me. I may just have to save an empty spray bottle if I encounter this in the future.RickHaleParker wrote: 04 Feb 2018, 18:45 Take the top off a spray bottle and pump the oil out to a paper towel or into the bottle.
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
This would also help abscate reuse the oil in another carRickHaleParker wrote: 04 Feb 2018, 18:45 Take the top off a spray bottle and pump the oil out to a paper towel or into the bottle.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
I would lose too much transferring into a bottle - I want to transfer it directly....Teddy1975 wrote: 05 Feb 2018, 11:08This would also help abscate reuse the oil in another carRickHaleParker wrote: 04 Feb 2018, 18:45 Take the top off a spray bottle and pump the oil out to a paper towel or into the bottle.![]()
- RickHaleParker
No problem, go to a boating supply and get one of them Primer Pump Bulbs use to prime portable fuel tanks.
Add hoses to the bulb, stick the from hose in the source oil, sick the to hose in the destination and start pumping the bulb. This is now I make self priming siphon hoses.
Active
Past
Past
- 3079 Views
Last post by Roger_850T
- 12 Replies
- 4621 Views
- 3903 Views
- 1027 Views
Last post by ashlee2319
- 24 Replies
- 2434 Views
