Busted control arm, needs new CV Half Shaft too… worth the work?
moonweasel
- Year and Model: 2002 S60 2.4L non-T
- Has thanked: 31 times
Re: Busted control arm, needs new CV Half Shaft too… worth the work?
Thanks George, yeah, others on here have recommended getting a used Volvo half shaft over a new one… I used FCP Euro for the Lemforder control arm/ball joint package and will probably use them again if I end up needing to buy a new CV joint too.
2002 S60 non-turbo, 114k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It looks original and with the expected rust/dirt coming from the NY state. Try the bearing by hand, it should turn quite smooth, and check the boots for cracks.moonweasel wrote: ↑02 Feb 2018, 10:36 Lemforder control arms and ball joints are on their way. Found a shop locally who said they'd install those and the CV assembly for ~$450, which seems reasonable.
Can anyone tell me if this looks like it's in good enough condition or not?
https://www.ebay.com/itm/Volvo-S60-V70- ... 2483583729
- Has thanked: 1505 times
- Been thanked: 3818 times
It doesn't get much better than buying used auto parts from a minister...kudos to a western NY!oragex wrote: ↑02 Feb 2018, 15:29It looks original and with the expected rust/dirt coming from the NY state. Try the bearing by hand, it should turn quite smooth, and check the boots for cracks.moonweasel wrote: ↑02 Feb 2018, 10:36 Lemforder control arms and ball joints are on their way. Found a shop locally who said they'd install those and the CV assembly for ~$450, which seems reasonable.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
I can tell what I did. I crashed my 05 XC70 w/ 175k miles on it, bought another 05 XC70 w/ 215k miles on it, swapped everything: powertrain, interior, exterior (what survived). Cost me $2200 and two months spent in garage at evenings and undisclosed amount of beer.
The reason I don't want another car is they are all cr*p. Even our new Volvo XC60 is cr*p, it's not anywhere near my XC70 in terms of comfort and durability. We looked at a lot of "luxury" cars when we were shopping for wife's new car, doh, MB, BMW, Audi are not like they used to be 15 years ago. Domestic "luxury" is at the level of Korean cars these days. Volvo was a lesser disappointment among all, though it's not that ol' good Swedish car we all used to drive.
If I were you I would spend $2000 rebuilding suspension and steering using original parts, to start with. The work you mentioned I do in one evening. Inexperienced car mechanic can certainly manage it over weekend.
- 4633 Views
Last post by SuperHerman
- 1522 Views
Last post by Seaway
