Hi Friends - my son was in a fender bender with his 2007 S60 T5 and the driver-side curtain airbag deployed. The car is very fixable, but I'm concerned about successfully replacing the airbag. I can get a replacement airbag on eBay, though various forums seem to indicate that I need to also replace an SRS module and/or a software reset at the dealer.
Does anyone know the exact parts and process to replace the curtain airbag?
Thanks!
Curtain airbag deployed
- RickHaleParker
- Been thanked: 979 times
If the car will not start it is in crash mode. You will need Vida-DiCE to get it out of crash mode.
Active
Past
Past
- RickHaleParker
Replace the air bag and reset the SRS warning. Vida-DiCE can reset the warning.
Active
Past
Past
- RickHaleParker
Just make sure you disconnect the battery before you do any work. You would not want the new air bag to deploy when your installing it.
Hope he knows better or comes back and reads this.
Active
Past
Past
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
When a side airbag deploys does it take out a trim strip? I'm thinking the trim won't stay because the gripping ridge has been broken off.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
It should break at least partially.Georgeandkira wrote: 09 Feb 2018, 05:29 When a side airbag deploys does it take out a trim strip? I'm thinking the trim won't stay because the gripping ridge has been broken off.
The air bags shouldn't deploy for just a "fender bender" though. I'd never want to fix and drive a car that had the airbags deployed. But each to his own.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
All the bags in my car blew, serious crash totalled it. I got it after a body guy fixed it.Rattnalle wrote: 09 Feb 2018, 05:37It should break at least partially.Georgeandkira wrote: 09 Feb 2018, 05:29 When a side airbag deploys does it take out a trim strip? I'm thinking the trim won't stay because the gripping ridge has been broken off.
Has a salvage title, don't bother me.
I've never sold a car in my life.
Run em til they expire.
- 1017 Views
Last post by E Showell
- 589 Views
Last post by Memuns
- 10 Replies
- 1924 Views
Last post by mrbrian200
- 609 Views
Last post by dhanan84
- 599 Views
Last post by treestone27
