I have a coolant leak a little bit driver side of center near the firewall. It has left a small puddle of coolant the last two times I left it to idle.
Anybody have an idea of the culprit?
Sorry for the weird perspective.
Thanks in advance.
Coolant Leak
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Could be dripping down from the PCV tube coolant connection. It's a bit of a pain to get to and see without removing a few things.
Hmm...
Hmm...
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Been thanked: 504 times
- If not already replaced, I don't know how your turbo coolant hoses didn't burst yet at 23 years old...
viewtopic.php?t=55306
- Has thanked: 312 times
- Been thanked: 818 times
Agreed, turbo coolant lines. And actually plenty of them make it this many years, the relevant measure is miles not years, but they do probably look like mush. I'd figure it out and fix it before driving much if at all.
- Has thanked: 1611 times
- Been thanked: 4072 times
The OEM hoses are high quality , long lasting stuff
I did my first cooling system refresh on my 99 At 150k, 15 years
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The cars built prior to '99 do not have that coolant line.ecbsykes wrote: 12 Feb 2018, 18:39 Could be dripping down from the PCV tube coolant connection. It's a bit of a pain to get to and see without removing a few things.
Hmm...
- rspi
Contact rspi..
1. Turbo pressure.
2. Heater supply.
3. Heater return.
4. Lower radiator.
You'll need to pull the intake and feel around.
2. Heater supply.
3. Heater return.
4. Lower radiator.
- rspi
Contact rspi..
If you have to replace a heater hose, get and replace the firewall junction as well. It will likely break when you unplug the quick disconnect (23 year old plastic).
FlyingVolvo
Good to know, thanks!
2023 V60 T8 PE
2023 V60 T8 PE
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
I'm going to guess turbo coolant hoses.
- 16 Replies
- 4508 Views
Last post by granite
- 16 Replies
- 5415 Views
Last post by lcc014
- 1655 Views
Last post by DanSC
- 4139 Views
Last post by SuperHerman
- 9 Replies
- 4521 Views
Last post by rspi
