IPD sale Volvo Parts
Brakes a bit squidgy
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
qwertyjjj
Year and Model: V70 2004
Re: Brakes a bit squidgy
Post by qwertyjjj » Mon Jan 15, 2018 6:08 pm
Pumping the brakes seems to make them tighter for 5 seconds or so then back to spongey.
jonesg
Year and Model: 2004 V70
Has thanked: 2 times
Been thanked: 12 times
Wales
Post by jonesg » Mon Jan 15, 2018 6:32 pm
I would bleed them.
nickbw898
Year and Model: xc702002
Great Britain
Post by nickbw898 » Wed Jan 17, 2018 1:13 am
Another question: what did you top up the power steering with ATF? If so that's wrong it should bee CHFS II which is bright green and not very viscous - there were errors in some early Volvo handbooks saying 'use ATF' (red) using ATF will destroy the 'O' ring seals - no more power steering!
chrism
Year and Model: S80 / 2005
Been thanked: 9 times
Post by chrism » Wed Jan 17, 2018 8:27 pm
OK, forget what I said about the loss of vacuum assist. This latest clue points toward a failing master cylinder.
qwertyjjj
Post by qwertyjjj » Wed Feb 14, 2018 6:46 am
Brakes were bled but the mechanic couldn't find any leak. 2 weeks later they are getting soft again.
Any pointers as to what the issue could be?
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 117 times
Been thanked: 385 times
Trinidad & Tobago
Post by abscate » Wed Feb 14, 2018 10:07 am
If you replaced the master cylinder one of the calipers has a leak, or one of the brake lines. You should be able to confirm by finding the brake level dropping in the reservior - then use your nose to find the stinky leak.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
qwertyjjj
Post by qwertyjjj » Wed Feb 14, 2018 10:28 am
Mechanic did mention one of the calipers was rusty but couldn't see or smell anything. Slow leak?
Trinidad & Tobago
Post by abscate » Wed Feb 14, 2018 1:34 pm
If it is frozen, it will give you a bad pedal by letting the hoses swell instead of building pressure. That might be it.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
qwertyjjj
Post by qwertyjjj » Wed Feb 14, 2018 6:20 pm
It was braking well after bleeding so would have expected it to be a bad immediately after if caliper was stuck.
Trinidad & Tobago
Post by abscate » Wed Feb 14, 2018 7:09 pm
I've had a stuck caliper that gave me weird feeling brakes, some of the time. I'm guessing though, can't fault your reasoning.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Who is online
Users browsing this forum: turbosundance, XC70Rider and 36 guests
