1999 Volvo V70XC Hard Start - Check Valve install Topic is solved
This topic is in the MVS Volvo Repair Database » Fuel System Check Valve Installation P80 Volvos
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Seboroth, good write-up and photos! This in in the Volvo Repair Database, and I made your account "Contributor".
Also -> Amazon link
Seboroth_V70XC
Year and Model: Volvo V70XC 1999
Post by Seboroth_V70XC »
Thank you very much! I'll keep contributing as much as I can.
robbiewilso
Year and Model: V70 2000 XC SE
Has thanked: 2 times
Post by robbiewilso »
Followed your pictorial pretty much exactly and have no leaks (YAHH!) and will hopefully have better starts. The fittings I went with are pretty much exactly as pictured and if I ever have to redo the fuel pump I can replace this contraption with a standard fuel filter easily! Thanks for doing all the hard work of figuring it out.
Update- 24 hours later and several successful starts after sitting for hours/overnight. No more killing the starter! Thanks again for the superb pictorial and step by step. I used a dremel with a cutoff wheel to shorten the inlet port and cut off the barbed end of the outlet. I actually put a thin strip of rag inside it to make sure no metal shavings got into the filter itself.
