Hello;
1998 Volvo Volvo S70 T5-M; I cannot shift into any gears with out (grinding). What should I do first?
Thank you.
98 S70 T5-M; will not go into any gears
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
How does the clutch feel? Is your brake fluid reservoir at the max line? How many miles on the clutch and what is your driving style?
Knows enough to be dangerous
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
The clutch padel goes all the way to the floor (no resistance).
The brake fluid is max line (but I think I have a leak). I used to have to add brake fluid every two weeks of driving (M-F) work only.
Normal driving, work (M-F).
98 S70 T5-M Brick for life
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
+1, Check the fluid in the brake fluid reservoir. Then have the clutch checked.
- rspi
Contact rspi..
If the slave cylinder is leaking and can't build pressure, it won't work.
- rspi
Contact rspi..
tryingbe
- Year and Model: None
- Been thanked: 26 times
Depend on your vin, you can have an internal or external salve cylinder.Juan62 wrote: 20 Feb 2018, 09:32 What is a slave cylinder and where can I locate it to check for any leaks?
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
The slave cylinder turns fluid pressure into mechanical motion. It is at the transmission end of the clutch hydraulic line. It may be inside or outside of your clutch housing. On a 98 it "should" be outside. That makes it easier to repair.Juan62 wrote: 20 Feb 2018, 09:32 What is a slave cylinder and where can I locate it to check for any leaks?
Have a helper operate the clutch pedal, while you look for motion at the clutch release lever that goes through the side of the transmission/clutch housing. If there is no movement, your clutch hydraulics are the problem.
PS I accept donated broken Volvos
Current Volvos:
- RickHaleParker
- Been thanked: 979 times
A slave cylinder is a hydraulic cylinder that disengages the clutch when you push down the clutch pedal.
The Clutch Master cylinder is on the firewall. The Clutch Slave Cylinder is on the front edge of the transmission. Just follow the hydraulic lines from the firewall to the transmission.
There is more then one type, if you end up needing one, your need your Chassis number to figure out which one. Your Chassis number is last six digits of your Vehicle Identification Number (VIN) with any leading zeros removed. (i.e. 000123 = 123). You can find your Vin number on the plate in the corner of the windshield or on your title.
Active
Past
Past
- 1162 Views
Last post by wizechatmgr
- 36 Replies
- 4085 Views
Last post by firestarterpro
- 3135 Views
Last post by Mr. Detail
- 1893 Views
Last post by kallekula
- 9 Replies
- 2126 Views
