Good general rules, and there are even a few more options. You can also interchange a stock 97-98 2.4 turbo (the GLT turbo; note the 96 and earlier the GLT was not turbo) with a stock 94-98 2.3 turbo (the T5), all you want. Keep the same turbo in place or use a T5 ECU if you are swapping a T5 engine into a GLT.
There is a break in the auto transmissions speed sensor setup between 95 and 96, with the way the speedo gets the signal. It is easy to fix but takes a little DIY of splicing wires, worth noting if you are talking about swapping auto transmissions between years.
Blown Headgasket Engine Swap Compatability [850xs70]
- Has thanked: 311 times
- Been thanked: 817 times
neilalexander
- Year and Model: 96 850R
Awesome, thank you!
ToriWhite
- Year and Model: 1996 850
- Has thanked: 20 times
- Been thanked: 6 times
Time to run some more VIN's! Fingers crossed its not turbo!Ozark Lee wrote: 19 Feb 2018, 23:12 If the '98 S70 is a N/A (non turbo) car it is the same engine and will bolt right up. The differences between the 850 and the 98 S/V series is cosmetic. Under the hood they are the same other than some fuse box refinements. Starting in '99 everything is dramatically different but the '98 will work fine.
- 1588 Views
Last post by wizechatmgr
- 20 Replies
- 4867 Views
Last post by erikv11
- 11 Replies
- 2153 Views
Last post by Ozark Lee
- 12 Replies
- 3729 Views
Last post by precopster
- 648 Views
Last post by TallyX12
