How to jump start another car using a V70?
mdewalle
Year and Model: 2001 V70 2.4T
Has thanked: 23 times
Post by mdewalle »
The other day I was at a gas station and the guy next to me had a dead battery and asked me for jumper cables. I had the cables but when I opened my hood I realized I didn't know where to hook up both cables. I knew my battery is in the trunk, but when I took a look at that it became clear that it's a project to get to that.
We used my cables but a third car to get the guy going. Is there a way to hook up both cables under the hood on a Volvo to start someone else's engine?
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
There's a plus terminal behind the air filter box that works well for this. It's got a small plastic flap over it with a plus sign on it.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I never had luck using the red connector under the hood along with a ground near the engine. The engine would simply not crank. Maybe I didn't use the right ground point.
However it worked every time when attaching the cable at both poles at the battery inside the trunk. Reason why I threw away the battery cover and just keep a piece of cloth over the posts (just as an extra safety feature so as not to ground the red post). Gives access right away to the battery if needed.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
I've kept the plastic cover for my S60. The plan is to cut away both corners than reattach those pieces with some sort of hinge so that I can get to the battery terminals with jumper cables without going through the trouble of removing the plastic cover. I agree it's so much easier to jump start another car from the battery in the back. I did it once, removed the cover, and never put it back. I used part of a large inner tube draped over the battery to protect the terminal.
Rattnalle
Post by Rattnalle »
I've used the hood connectors a few times and it's works like a charm. I connect the ground wire to the ground connectors on the inside of the fender.
Both starting my own car and helping start others.
oragex
Post by oragex »
Rattnalle wrote: 24 Feb 2018, 12:39 I've used the hood connectors a few times and it's works like a charm. I connect the ground wire to the ground connectors on the inside of the fender.
Will keep that in mind for the next time, as a grounding point.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
One of the strut mount nuts is also a good ground
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Remember that there's an engine ground strap fairly low on the right side (passenger's side No.America) going to the firewall.
They can corrode away so inspect yours once in a while.
I'm not recommending this braided strap as a jumping ground.
I open the jumper's black clamp and bite two of the bolts on the fender's edge.
