I used 16 quarts and I would say it looked pretty close to the color of the tranny fluid bring poured in. I agree will drive it for a few months then reassess.
Mpls or Minneapolis is located in Minnesota.
External tranny cooler
You are doing them a big favour demystifying car maintenance, even if they don't end up,wrenching themselvesStellablue wrote: 24 Feb 2018, 17:16 My daughters and I did it through the disconnected cooling line. I figured they should learn how to work on cars too. The fluid was really dirty. I am thinking about driving the car for a few hundred miles or more and do another.
Between mine and friends I think I have tortured 18 Young ladies in the Car talk school , and learned how to drive stick. Too
- June
- Has thanked: 523 times
- Been thanked: 261 times
I could not agree more abscate. Knowledge is paramount to prevent unscrupulous salespeople from ripping us off, or lack of maintenance killing the car. Juneabscate wrote: 25 Feb 2018, 19:50You are doing them a big favour demystifying car maintenance, even if they don't end up,wrenching themselvesStellablue wrote: 24 Feb 2018, 17:16 My daughters and I did it through the disconnected cooling line. I figured they should learn how to work on cars too. The fluid was really dirty. I am thinking about driving the car for a few hundred miles or more and do another.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Transmission fluid gets over 110 C real easy in summer, 120+ in a hot day. Degrading properties of ATF is not a problem, the problem is a few places in transmission that get overheated or oil starved because of thin hot fluid. Slack in a differential, bearing noise, pressure loss is what usually happens at the end.
Hayden transmission cooler looks good and can be mounted without piercing the other radiators.
Stellablue
- Year and Model: 2004
Thanks for the suggestion! I am still bouncing around the idea of an external tranny cooler. Quick question, did you have take off the front bumper in order install the tranny cooler.vtl wrote: 28 Feb 2018, 05:48 Transmission fluid gets over 110 C real easy in summer, 120+ in a hot day. Degrading properties of ATF is not a problem, the problem is a few places in transmission that get overheated or oil starved because of thin hot fluid. Slack in a differential, bearing noise, pressure loss is what usually happens at the end.
Though I do have say the car is running very smooth after the flush. Like I said before I thought it was running fine before the flush but after the flush there has been definite improvement.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Please describe the procedure. Are there plastic clips, mushrooms or expanding pin fasteners one should buy in advance?
The last part is because I live near a competent auto body supply house which has all the fasteners you could ever imagine mounted on the wall.....MUCH cheaper than going to the dealer or buying them in 4 packs.
- 9 Replies
- 3292 Views
- 1720 Views
Last post by justanotherhumanoid
- 1583 Views
Last post by SuperHerman
- 2074 Views
Last post by fitz548
- 337 Views
Last post by jonesg
