98 S70 non turbo loss of power
45DegreesPDX
- Year and Model: 1998 S70
Just pulled out the spark plugs, and I'll definitely be replacing them.
I also noticed a crack in my alternator, think this could be an issue? I'll definitely replace it, just trying to see if it might be a source of my symptoms.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Yeah, those spark plugs are pretty well toasted. How do your plug wires look? That crack is definitely not good. With the engine running, check the voltage of the battery with a volt meter. If it's under 12.5V, the alternator is likely not supplying adequate power. And make sure you pull the distributor and check that as well.
Knows enough to be dangerous
45DegreesPDX
The plug wires look okay, nothing too out of the ordinary, but I figured I'll replace them anyways while I've got everything taken apart. I'll be able to check the cap either later tonight or tomorrow. Am I looking for dirt and grime or just damage in particular?
- WhatAmIDoing
You are looking for dirt, evidence of arcing (google arcing in distributor), and wear on the pins and rotor. Post a picture if you can and we'll tell you whether it looks good. I'm guessing it's probably time to replace.
45DegreesPDX
Yeah, it looks likes its time to replace these.
Also, when I was taking off the airbox, I accidentally broke what I think is the preheat hose that connects to it. Is this easy to replace that I can do myself with some clamps?
Thanks for all your help!!
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Yeah, plugs, cap and rotor could stand replacement. The crack on the alternator is just on the plastic ring though, right? If so, not critical
Current Volvos:
- WhatAmIDoing
I agree with FLXC90. Time for a tune up: new plugs, wires, cap, and rotor. Only use Volvo, Bosch, and/or Bougicord (wires) for these parts. FCP sells some good tuneup kits using OE parts.
You mean the rubber elbow that connects to the white line? I have a turbo, so not sure what all hoses run to/near the NA airbox. Picture would help.45DegreesPDX wrote: 27 Feb 2018, 00:38 Also, when I was taking off the airbox, I accidentally broke what I think is the preheat hose that connects to it. Is this easy to replace that I can do myself with some clamps?
45DegreesPDX
No it's silver and rigid. Looks similar to a dryer hose connection and connects behind the engine near the firewall to the exhaust system. I'll post a picture tonight.
- Has thanked: 311 times
- Been thanked: 817 times
Broke preheat hose is of no consequence, take your time on it, and yes you can easily DIY replace this no-clamp hose. You can get a generic replacement from Autozone or similar (I know they have them at Advance Auto and O-Reilly's, around here).
For where you live in Portland OR, you could also just throw away the preheat hose and inside the air box wedge the flap permanently to the "cold" (outside) air side.
- WhatAmIDoing
Oh that hose. I wouldn't even worry about it. It's hardly important. Should be easy and cheap DIY fix.45DegreesPDX wrote: 27 Feb 2018, 16:12 No it's silver and rigid. Looks similar to a dryer hose connection and connects behind the engine near the firewall to the exhaust system. I'll post a picture tonight.
- 891 Views
Last post by 93Regina
- 38 Replies
- 12255 Views
Last post by mrbrian200
- 3384 Views
Last post by jonesg
- 9 Replies
- 1395 Views
Last post by hendrixscottie
- 1899 Views
Last post by ollebompa
