Fuel injectors
dha89
Year and Model: 2006 S60 2.5t
Fuel injectors
Post by dha89 »
I'm searching for a new fuel rail for my 2002 volvo v70 xc 2.4l turbo. I keep finding ones for different vehicles that have the same set up but different color injectors. I have the orange injectors. Are there a big difference in the injectors I've seen green and what looked like grey. If I get one with different injectors are there any that would improve the performance of the car or will it basically be the same? I'm looking for a new set up bc my pressure regulator won't stop leaking no matter what I do to fix it and the delivery line is leaking around the hose where it connects to the fuel rail fitting
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
dha89 wrote: 26 Feb 2018, 15:22 If I get one with different injectors are there any that would improve the performance of the car or will it basically be the same?
If you use injectors that are not matched with your ECU, performance of the car will go down and you run a risk of blowing the engine up.
85 GLH, 367 whp
00 Insight, 72 mpg
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
Can't you mate your existing injectors to a new rail?
Has thanked: 1503 times
Been thanked: 3817 times
How about replacing the 99 cent Oring on the fuel line and the FPS?
dha89
Post by dha89 »
I said no matter what I do to fix it. The first thing I did was replace the oring. I've put 3 on it. It's not leaking around the oring. And it's also not the only thing leaking. And yes I can put my injectors in the rail I was just wondering what the difference was. When I was building hondas we used to swap injectors and stuff all the time but I've found out volvos are a completely different story from what I'm used to
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
the pull a part yard N of Winston Salem has several volvos to choose from
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
