94 850 Turbo barely runs Topic is solved
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
So this am jumped in the car that I had driven Saturday for 100 or so KM without a hiccup and it started- sort-of idled at 500 rpm wouldn't respond to the throttle then it stalled, I was able to restart it a couple of times for a second or two until I grabbed the wife's V70 and headed off to work. I checked that I hadn't blown off an intake hose, I lean towards the MAF or fuel injection relay
- skloon
Okay got home swapped fuel injector relay and it didn't start- unplugged MAF and it started blew a ton of smoke- re plugged in MAF checked codes and it runs swapped old relay and again it didn't start so I guess it was the relay
- Has thanked: 1834 times
- Been thanked: 1709 times
Glad it turned out to be a relatively simple fix!
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Those relays will get ya.
Knows enough to be dangerous
