98 S70 N/A 5-speed, Rear Spring Question: Correcting Rear-end Sag
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
tryingbe wrote:I can sell you a set of Volvo OEM spacers and bolts to raise up the rear. There are washers in place so the springs can't wander off.
Hey, tryingbe, thanks for the message. I've never seen these before! Are these used primarily for raising saggy springs?
Retired:
2015 Volvo S60, T5, 85K
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
Since we're sharing pictures of saggy rear ends, I thought I'd offer mine for critique. I hadn't thought to measure from the wheel center on the 2000 V70 base MT, instead trying to determine the height of the tire to the fender. It's about 1.25" on the rear, and about 2.5" in the front.
The more I've worked on this fixer-upper, the more I've enjoyed driving it, and I'm thinking that new springs and shocks would do wonders for it. My brother (thewifes_s70) and I replaced the front struts but not the springs.
The previous owner had a 1.25" hitch on the car, so my guess is that towing might have caused the rear springs to wear prematurely. It needs new shocks anyway, so I'm hoping it's not that much more work.
(And yes, that is a newer V70 in the driveway in the background — not mine.)
'00 V70 side view
'00 V70 side view
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Has thanked: 1611 times
Been thanked: 4075 times
If you dig back in my posts I made measurements on the rear ground to fender with old and the New springs to compare
I’ll try to find thread
viewtopic.php?f=1&t=63781&hilit=1999+ride+height
Has thanked: 312 times
Been thanked: 818 times
abscate wrote: 27 Feb 2018, 19:03 If you dig back in my posts I made measurements on the rear ground to fender with old and the New springs to compare
Now that you've run them a while, what is your assessment of the IPD overload rear springs? I like them on my 98.
I love the ride on the 99. I did all four corners at about 160k miles (40k ago) and it’s a tight ride, not too bouncy
I did IPD springsfront back and Sachs for struts
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
abscate wrote: 28 Feb 2018, 01:23 I love the ride on the 99. I did all four corners at about 160k miles (40k ago) and it’s a tight ride, not too bouncy
I can feel the difference in yours vs mine with your newer front end suspension. At lot better "go where indicated" on it. Mine wanders just a little bit.
The rear on mine could have been used to ship materials to the space station with an appropriately side speed bump or pot hole at speed before those assemblies were replaced.
2023 Lexus RZ450e -66k
