External tranny cooler
Stellablue
Year and Model: 2004
Post by Stellablue »
I used 16 quarts and I would say it looked pretty close to the color of the tranny fluid bring poured in. I agree will drive it for a few months then reassess.
Mpls or Minneapolis is located in Minnesota.
Has thanked: 1611 times
Been thanked: 4072 times
Stellablue wrote: 24 Feb 2018, 17:16 My daughters and I did it through the disconnected cooling line. I figured they should learn how to work on cars too. The fluid was really dirty. I am thinking about driving the car for a few hundred miles or more and do another.
You are doing them a big favour demystifying car maintenance, even if they don't end up,wrenching themselves
Between mine and friends I think I have tortured 18 Young ladies in the Car talk school , and learned how to drive stick. Too
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
abscate wrote: 25 Feb 2018, 19:50
I could not agree more abscate. Knowledge is paramount to prevent unscrupulous salespeople from ripping us off, or lack of maintenance killing the car. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
vt9000cse
Year and Model: 2003 Saab 9-3 Linear
Post by vt9000cse »
MPLS in Minneapolis, MN.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Transmission fluid gets over 110 C real easy in summer, 120+ in a hot day. Degrading properties of ATF is not a problem, the problem is a few places in transmission that get overheated or oil starved because of thin hot fluid. Slack in a differential, bearing noise, pressure loss is what usually happens at the end.
Hayden transmission cooler looks good and can be mounted without piercing the other radiators.
Stellablue
vtl wrote: 28 Feb 2018, 05:48 Transmission fluid gets over 110 C real easy in summer, 120+ in a hot day. Degrading properties of ATF is not a problem, the problem is a few places in transmission that get overheated or oil starved because of thin hot fluid. Slack in a differential, bearing noise, pressure loss is what usually happens at the end.
Thanks for the suggestion! I am still bouncing around the idea of an external tranny cooler. Quick question, did you have take off the front bumper in order install the tranny cooler.
Though I do have say the car is running very smooth after the flush. Like I said before I thought it was running fine before the flush but after the flush there has been definite improvement.
vtl
Post by vtl »
Bumper removal is 10 minutes when you do it the first time. I think I can take off in under 3 minutes :)
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Please describe the procedure. Are there plastic clips, mushrooms or expanding pin fasteners one should buy in advance?
The last part is because I live near a competent auto body supply house which has all the fasteners you could ever imagine mounted on the wall.....MUCH cheaper than going to the dealer or buying them in 4 packs.
