1996 850 GLT No crank no start
- Has thanked: 1611 times
- Been thanked: 4072 times
I’ve got an almost new one in my parts thread , but don’t be in BOSTON until a week from Tuesday.
- RickHaleParker
- Been thanked: 980 times
Check the grounds on the starter and make sure it getting voltage to both the starter and solenoid. I have seem bolts looses up, wires come loose or burn out and cause the symptoms you have. If you can get to the starter, Jump the "50" terminal to the positive battery cable. See attached file.
1995-96 850 Starting & Chargeing System.pdf- (127.36 KiB) Downloaded 143 times
Active
Past
Past
You pretty much have to remove it to service any of that stuff , Rick, and once it’s off, next stop, rebuild electrical shop for the smart money.
- RickHaleParker
He should be able to get to the solenoid without pulling a bunch of stuff off. I'm suggesting he do some diagnostics at the solenoid before he pulls off. the starter In other word, make darn sure it not an electrical issue before pulling the starter.
Active
Past
Past
I'm thinking it could be the pigtail between the motor and solenoid but I can't see dealing with that on the car.
UPDATE: I picked up a new aftermarket starter that is a favorite on Rock Auto($65+/-) and also had good reviews on Amazon. The installation of this was somewhat of a nightmare. Much had to be removed to make enough room for the r&r. Removing the fan from the fan shroud required dealing with rusted torx head screws that the correct tip would no longer grip enough to undo. On the bottom 2 I had to use long nose vise grips to grab the fastener by the side of it's washer head which took a lot of time, aggravation and swearing. Upon reassembly I tossed those screws and used 1/4" hex head lags with washers instead.
The starter topmost bolt was rusted/ welded into place(galvanic reaction) Finally got it to start turning with a breaker bar and pipe extension. Ended up that the bolt didn't turn but broke instead. Luckily with all the bolts on starter removed I was able to get a long screwdriver onto the starter body and whack it loose with a 3# hammer. Once the starter was out I had to drive a new bolt through the top starter mount hole to clear all the corrosion out so the new bolt would pass through.
After reassembly the car fired right up. I am going to try removing the remains of the broken bolt from the original starter and see what an auto electric guy would charge for rebuild of it. If reasonable will keep on shelf just in case. If I need to do this again on this car I would attack it this same way since I replaced the torx with hex head but on a different car would prob remove the entire radiator/ shroud assembly.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Make sure those hex lags are stainless unless you want another problem to add to your list.
That said, if the plan is to keep the car short term, I wouldn't bother.
2023 Lexus RZ450e -66k
- RickHaleParker
Galvanic Corrosion requires two things.
- 1. Two dissimilar metals.
2. A Electrolyte.
Active
Past
Past
