then this new bolt will cut new threads
Tap and Die sets start at $15.00 ...
Head gasket job. Won't start
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
- Been thanked: 4069 times
...and you can buy individual taps, of the correct hardened steel, for about $5 at Lowe’s
I like the boltbtrick but if zombies had confiscated the taps. I would use a Dremel to make the taper on the bolt
- Has thanked: 311 times
- Been thanked: 817 times
A $15 tap and die set lol ... run away fast from that one!
Kobalt brand taps probably good into aluminum for several jobs. On a critical engine part I would buy a new one
Agreed. And the bare bones starter set is probably $25.
But really, if one is going to buy more than a single tap it can be well worth the investment to spend a couple more bucks on a nice(r) set with a range of sizes.
Kazbear
- Year and Model: 2000 v70
Thank you everyone.
I bought one of those heli-coil kits online and it worked.
Another thing I am learning about working on an older car, is all the plastic stuff is brittle. I had to replace the coolant tank (already cracked, I just helped it along) and the radiator (same deal).
And the rubber hoses just disintegrate.
After all that, and re seating the cam cover (major oil leak, I think one of the cam seals was not set properly) she runs great. No more coolant or oil leaks. No over hearing. So far all seems good...
Except a P1618 code...
So, this is what I accomplished because of this site:
1. Head gasket replacement
2. Timing belt replacement
3. Water pump replacement
4. Valve job
5. Radiator replacement
I won't lie. I am surprised the car ran after I was done.
Now what do I do with all these left over bolts?
4. Valve job
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
They work great across the end of your driveway (positioned standing up, head down) when you have neighbors that keep blocking it - they tend to pick them up =p
- wizechatmgr
The P1618 could be CAN BUS between Tranny and Engine control module or I believe *cringe* it may be able to be caused by a bad ABS module.
Try making sure you have a good (and charged ~12.8V+) battery and then clear it. If it was started with a crappy or low battery it may trigger all kinds of interesting codes.
If you get VIDA + a DICE box you can read from the transmission module exactly what it has seen and if there are any current codes. If you changed the ATF (DEX/MERC?) you're going to want to run an adaption and a counter reset.
- 1306 Views
Last post by goldmandan
- 1315 Views
- 13 Replies
- 978 Views
Last post by Roger_850T
- 25 Replies
- 1604 Views
Last post by Maestrours
- 18 Replies
- 6083 Views
