2004 C70 P80 platform Check DII codes without scanner (DTC menu)? Check engine light on '04 c70, OBDII shows no codes.
Hellmark
Year and Model: 2004 C70
Post by Hellmark »
Hello, having some issues on my 2004 C70, and hope you can help.
Last night when I parked my car, I noticed tail lights were still on after the car was off and key out of ignition. Got in, started up, and it immediately went into winter mode and wouldn't exit. Turned off and on a few times, shifting through each position. Eventually it went out of winter mode, but now check engine light is on. Ran code reader with Torque but didn't get a faults. I check online to see if there was something else I can do and see mention of pulling up the DTC menu by holding the read button on the turn indicator while ignition set to II, and toggling the fog lights. No dice. See others complaining about that method not working for their C70s either.
Anyone got a clue? I can't afford to take it in to the dealer, plus I don't have one close by.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Does not give the codes per se.
Volvo hidden menu – procedure
  • Turn ignition to II position.
    Press and hold [READ] button on the left stalk AS you Press [rear fog lights] button twice.
    You should see “CHECKING DTCS” message on the DIM.
    Release the [READ] button.
    After few seconds you should see “DTCS IN VEHICLE” message.
    Use READ button to browse through the hidden menu.
Modules will be listed with information about present DTCS:
DTC SET – errors found in module
CHECKING – waiting for information from module
READY – no errors
Volvo hidden menu modules list (all models)
  • ABS – Anti-Lock Brake System
    ADM – Additive Dosing Module
    AEM – Accesory Electronic Module
    AFM – AM/FM Tuner Module
    ATM – Antenna Module
    AUD – Audio Module
    AUM – Audio Module
    BCM – Brake Control Module
    CCM – Climate Control Module
    CEM – Central Electronic Module
    CPM – Combustion Preheater Module
    DDM – Driver Door Module
    DEM – Differential Electronic Module
    DIM – Driver Information Module
    ECM – Engine Control Module
    EPS – Electrical Power Steering Module
    ETM – Electronic Throttle Module
    IAM – Integrated Audio Module
    ICM – Information Control Module
    KVM – Keyless Vehicle Module
    LPG – LPG Module
    LSM – Light Swith Module
    MMM – Multimedia Module
    MPM – Media Player Module
    PAM – Parking Assistance Module
    PDM – Passenger Door Module
    PHM – Phone Module
    PSL – Power Seat Left
    PSR – Power Seat Right
    REM – Rear Electronics Module
    RTI – Road Traffic Information Module
    SAS – Steering Wheel Angle Sensor
    SHM – Seat Heating Module
    SRM – Sunroof Module
    SRS – Supplemental Restraint System
    SUB – Subwoofer Module
    SUM – Suspension Module
    SWM – Steering Wheel Module
    TCM – TransmissionMessage Channel Module
    TMC – Traffic Message Channel Module
    TRM – Trailer Module
    UEM – Upper Electronic Module
    WMM – Wiper Motor Module
Active
Past
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I don't think that's gonna work on a P80...
RickHaleParker
Your point being? or Are you being pointless?
Active
Past
Has thanked: 1611 times
Been thanked: 4075 times
THE C70 platform is still P80 in 2004, it is the late bloomer.
Hellmark
Post by Hellmark »
Yeah, did that and it didn't work.
dionescu
Year and Model: S80 2001
Post by dionescu »
OK, and how can we read the codes? It just tells us there is an error.
dionescu wrote: 19 Feb 2020, 13:57 OK, and how can we read the codes? It just tells us there is an error.
You use VIDA or a higher end (about 150 USD) code reader.
BEJinFbk
Post by BEJinFbk »
If you’re asking in regards to the 2001 S80
indicated in your profile signature, you’ll get
much more relevent responses in the S80
section of MVS:
viewforum.php?f=11
This is the forum area for the older P80 platform Volvos.
The 2004 C70 owner that originated this post has a unique
Coupe or Convertible that ran on the P80 platform for a few
years longer than the Sedans and Wagons.
Best of Luck!
It’s for a 2004 C70 , which is P80 platform, per first post.
It’s really good to follow the YEAR MODEL ISSUE format in the title
