The sheet metal attaching the door check spring on the driver side door tore away, leaving a hole in the door jamb. Looks like I have to weld a piece of sheet metal onto the door to fix this. Anybody else have any experience fixing this, and what to look out for?
Thanks,
-Bruce
2002 C70 door check sheet metal
- Has thanked: 2205 times
Don't recall reading anything on a C70, but not uncommon an issue on 850's and V/S70's. There have been a few threads on this, but try searching under check strap.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Unless you have either a really nice MIG setup or preferably a TIG and are quite experienced, you may want to forgo it and bring it to a local welding shop. Odds are it will be only a $100 repair - possibly cheaper. You don't want to overheat anything in there.
They may opt to use a spot welder.
May the force be with you...
- 2932 Views
- 1250 Views
- 11 Replies
- 2374 Views
Last post by Mr. Detail
- 9 Replies
- 6383 Views
- 9 Replies
- 3878 Views
Last post by deeperblue
